DES-3326SREOL EOS
Tanımlama
Scalable Expansion
Up to 13 DES-3326SR switches can be stacked together. Y ou can add units to reach maximum 312 10/100Mbps ports and 13 GBIC-based ports per stack. The switches are stacked together through high-speed stack cables that provide multi-gigabit per second back plane, allowing the entire stack to perform as a single entity.
Wire-speed IP Routing
The switch is designed for basic IP routing, with instant support for Windows, Unix and Internet environments. It provides wire-speed non-blocking switch fabrics with hardware-based packet filtering/forwarding. Packet routing is performed by on-board ASICs at speeds many times faster than CPU-based routers.
Seamless Integration
The switch can be instantly integrated into any existing network for seamless integration of Layer 2 and Layer 3 packet switching. With multi-layer support for every port, you can start with Layer 2 switching, then upgrade to Layer 3 routing anytime by simply re-configuring the ports. You can flexibly segment the network into domains and sub-domains, using (1) subnet IDs and user IP numbers to route traffic, and (2) custom filters based on users' physical MAC addresses to filter extraneous traffic. At Layer 2, the switch uses auto-learned and user-defined MAC addresses to discard and forward packets. At Layer 3, it looks at the user-specified routing table to route packets to their destinations.
Ready for Multimedia, Video Applications
With Priority Queues and IP multicast (IGMP snooping) support, Quality of Services (QoS) can be guaranteed for successful execution of delay-sensitive applications like video conference.
Flow Control to Prevent Packet Loss
The switch supports standard IEEE 802.3x Flow Control. Working in conjunction with buffer overrun auto-detection, this full-duplex data transfer mode provides protection against possible data loss for 802.3x supported servers directly connected to the switch.
Port Trunks for Aggregated Bandwidths
With low cost per port, port trunks supporting static Link Aggregation standard provide an easy and economical alternative solution for server connection to attain Gigabit bandwidth. Up to 8 10/100Mbps ports or 8 Gigabit ports can be combined together to create a multi-link load-sharing aggregated bandwidth to a server. Port trunks can span multiple units of the stack for fail-safe connectivity to mission-critical servers and the network center. Up to 8 multi-link trunks can be configured for a stack.
VLANs for Enhanced Security & Performance
VLANs improve security and bandwidth utilization by limiting the broadcast domains and confining intra-group traffic within their segments. To segment up the network, workstations supporting IEEE 802.1Q VLAN Tagging connected to the switch can be grouped into different Virtual LANs (VLANs). The switch also supports GVRP (GARP VLAN Registration Protocol) for automatic VLAN configuration distribution.
Advanced Network Access Management
802.1x features enable user authentication for each network access attempt. Port security features allow you to limit the number of MAC addresses per port in order to control the number of stations for each port. Static MAC addresses can be defined for each port to ensure only registered machines are allowed to access. By enabling both of these features, you can establish an access mechanism based on user and machine identities, as well as control the number of access stations.
Access Control Lists (ACL) allow the network administrator to define policies on network traffic control. The switch supports comprehensive and multi-layer ACLs, providing a powerful tool for network management. For example, the switch can be set to block malicious bulk traffic from specific clients (based either on MAC or IP addresses). Or during a virus attack, the switch can be set to restrict its flooding based on a virus's unique pattern (TCP/UDP port number).
Advanced QoS Support
The switch supports not only Layer 2 802.1p Priority Queue control, but also a variety of ways to prioritize network packets. Multi-layer information from L2 to L4 can be used to classify packet priorities. This function support allows you to attach IP telephony devices or video servers to the switch to run delay-sensitive applications like video conference.
Flexible Transmission Scheduling
The switch supports 2 methods of packet transmission scheduling: Strict Round-Robin (SRR) and Weighted Round-Robin (WRR). You can select to use SRR to strictly enforce your priority queues, or WRR to address bandwidth limitations at peak time. WRR allows each queue to be assigned a different percentage of the output port's bandwidth, so that lower-priority queues are not denied access to buffer space and port bandwidth.
IGMP Snooping for Broadcast Control
The switch listens to IGMP (Internet Group Management Protocol) messages to build mapping table and associate forwarding filters. It dynamically configures the switch ports to forward IP multicast traffic only to those ports associated with multicast hosts.
Broadcast Storm Control
To prevent too many broadcast/multicast packets from flooding the network, broadcast/multicast storm control is configured to screen excessive traffic. Threshold values are available to control the rate limit for each port. Packets are discarded if the respective count exceeds the configured upper threshold in a given time interval. The possible range of upper threshold is from 0 to 255k packets per second.
Port Mirroring
This function allows you to mirror adjacent ports for the purpose of analyzing incoming and outgoing packets where packet patterns can be studied. 802.1D Spanning Tree & 802.1w Rapid Spanning Tree Support For mission critical environments with multiple switches supporting STP, you can configure the stack of switches with a redundant backup bridge path, so transmission and reception of packets can be guaranteed in event of any fail-over switch on the network.
Multiple Management Interfaces
SNMP v.1, v .2c, v.3 network management is supported, using the built-in MIBs. RMON monitoring and SYSLOG are provided for effective central management. The switch also provides a Command Line Interface (CLI) and a Web-based GUI. CLI enables quick system configuration for administrators familiar with command line operation. The embedded Web-based interface allows you to easily access the switch from anywhere on the network and troubleshoot it in real-time. You can, for example, browse the MAC address table via the Web browser and perform searching to identify the location of any workstation. Port utilization graphs provide real-time traffic monitoring and diagnostic information.
Optional Ports (Stand-alone Configuration)
If you configure the DES-3326SR as a stand-alone switch, you can install the following modules in the open slot:
- 2-port Fast Ethernet module (10/100BASE-TX)
- 1 or 2-port Fast Ethernet multi-mode fiber module (100BASE-FX)
- 1 or 2-port Fast Ethernet single-mode Fiber module (100BASE-FX)
- 2-port Gigabit fiber module (1000BASE-SX)
- 2-port Gigabit fiber module (1000BASE-LX)
- 2-port Gigabit copper module (1000BASE-T)
- GBIC module (2 GBIC slots)
Gigabit Over Copper Twisted-pair
The optional Gigabit copper ports provide an inexpensive alternative solution to the fiber. Using your existing low-cost Cat. 5 twisted-pair wires as the transmission media, these ports allow you to instantly upgrade your servers to Gigabit capability without requiring you to install new, expensive fiber cables.
Redundant Power Support
The switch can be connected to an external power supply for redundant power backup purposes. In case the built-in internal power supply fails, the redundant power supply unit will automatically provide all the required power to ensure continuous operation. For redudant power supply, the following can be deployed:
- DPS-900 8-slot standard rack-mountable chassis, for installation of 8 DPS-200 power supply units for a stack of 8 DES-3326SR switches
Genel Özellikler
Hardware
Protocol
CSMA/CD
Data Transfer Rates
- Ethernet:
10Mbps (half duplex)
20Mbps (full duplex)
- Fast Ethernet:
100Mbps (half duplex)
200Mbps (full duplex)
- Gigabit Ethernet:
2000Mbps (full duplex)
Basic Configuration
- 24 auto-sensing 10/100Mbps ports (built-in)
- 1 open slot
Switch Fabric
8.8 Gbps
LED
- Power (per device)
- Console (per device)
- RPS (per device)
- 10/100Mbps speed (per port)
- Link/Act (per port)
Built-in Ports Supported Functions
- IEEE 802.3 10BASE-T/802.3u 100BASE-TX standards
- Full/half duplex support with ANSI/IEEE 802.3 NWay auto-negotiation
- IEEE 802.3x Flow Control in full-duplex, back pressure in half-duplex
- MDI/MDIX auto-sensing for all twisted-pair ports
- Auto-correction of twisted-pair Rx reverse polarity
- 10BASE-T cables:
UTP Cat. 3, 4, 5 (100 m max.)
- 100BASE-TX cables:
UTP Cat. 5 (100 m max.)
Optional Modules
DES-332GS Stack + GBIC Module
- 1 stacking port
- 1 GBIC slot (IEEE 802.3z/802.3ab standards)
- Stackable units: 13 switches per stack
- Stacking method: ring
- Full duplex support for GBIC slot
- IEEE 802.3x Flow Control (GBIC slot)
- Stacking cable: proprietary IEEE 1394 cable (provided)
- Network cables (GBIC slot): single-mode and multi-mode fiber
- LED report (per port): Link/Act (GBIC slot)
DES-132 10/100Mbps Fast Ethernet Module
- 2 10/100Mbps ports
- Auto MDI/MDIX for each port
DES-131F/132F Fast Ethernet Fiber Module
- IEEE 802.3u 100BASE-FX standard
- 1/2 100Mbps fiber port(s) (SC connectors)
- Cables: 50, 62.5/125-micron multi-mode fiber (2 km max.)
DES-131FL/132FL Fast Ethernet Fiber Module
- Cables: 9-micron single-mode fiber (15 km max.)
DES-132G Gigabit Fiber Module
- IEEE 802.3z 1000BASE-SX standard
- 2 Gigabit fiber ports (SC connectors)
- Cables: 50/125 micron multi-mode fiber (525 m max.), 62.5/125 micron multi-mode fiber (275 m max.)
DES-132GL Gigabit Fiber Module
- IEEE 802.3z 1000BASE-LX standard
- Cables: single-mode fiber (5 km max.)
DES-132T Gigabit Copper Module
- IEEE 802.3 10BASE-T/802.3u 100BASE-TX/IEEE 802.3ab 1000BASE-T standards
- 2 auto-sensing 10/100/1000Mbps ports
- 10BASE-T/100BASE-TX: full/half duplex
- 1000BASE-T: full duplex
- 10BASE-T cables:
- 100BASE-TX/1000BASE-T cables:
UTP Cat. 5/Cat. 5e (100 m max.)
100/1000Mbps speed
Link/Act
DES-132GB GBIC Module
- IEEE 802.3z standard
- 2 GBIC slots for installation of Gigabit transceivers
- Cables: single-mode and multi-mode fiber, twisted-pair cable
Software
IP Routing
- IP v4 support
- IP multi-netting
- IP Fragmentation support
- Routing protocols supported:
Static routing
RIP-1, RIP-2
OSPF v.2
VLAN
- IEEE 802.1Q Tagged VLAN
- Port-based VLAN
- Number of VLANs: 255 per device (max.)
Spanning Tree
- 802.1D Spanning Tree compatible
- 802.1w Rapid Spanning Tree
Multicast
- IGMP v2
- IGMP Snooping
- DVMRP
- PIM-DM
Priority Queues (CoS)
- Standard: IEEE 802.1p
- Number of queues: 4
Traffic Classification (CoS)
Can be based on user-definable application types:
- TOS
- Diffserv (DSCP)
- Port-based
- MAC address
- IP address
- TCP/UDP port number
Access Control Security
- Port security
- 802.1x user authentication
- RADIUS client
- Multi-layer ACL (Access Control List) based on:
Port number
TOS
Diffserv (DSCP)
MAC address
IP address
User-definable applications
Port Trunks
- Number of ports per trunk: 8 (max.)
- Number of trunks: 8 (max.)
- Operation mode: load sharing
Transmission Method
Store-and-forward
Performance
MAC Address Table
8K entries per device
MAC Address Learning
- Dynamic entries: automatic update
- Static entries: user-defined
Routing Table
2K entries per device
Layer 2 Packet Forwarding Rates (half duplex)
- Ethernet: 14,880 pps per port
- Fast Ethernet: 148,810 pps per port
- Gigabit Ethernet: 1,488,100 pps per port
Layer 3 Packet Forwarding Rate (half duplex)
6.6Mpps
RAM Buffer
16 MB per device (excluding optional modules)
Configuration & Management
Management Methods & Standards
- SNMP management v.1, v .2c, v.3
- Web-based management (via web browser)
- RMON monitoring
- Telnet (up to 8 sessions)
- CLI (command line interface)
Management Security
Password enabled
MIBs
- MIB-II (RFC 1213)
- Bridge MIB (RFC 1493)
- RMON MIB (RFC 1757)
- RIP (RFC 1724)
- OSPF (RFC 1850)
- CIDR (RFC 2096)
- 802.1Q VLAN MIB (RFC 2674)
- IGMP MIB (RFC 2833)
- If MIB (RFC 2233)
- Ethernet-like MIB (RFC 2358)
- dot3statsTable
- D-Link enterprise MIB
RMON Groups
1, 2, 3, 9 (Alarm, Statistics, History, Event)
IP Number Self-identification
- DHCP client
- Bootp client
Firmware Upgrade
TFTP
Console Port
DB-9 RS-232 DCE
Çözümler
Sipariş Bilgisi
10/100Mbps Stackable Layer 3 Switch
DES-3326SR 24 10/100Mbps ports , 1 open slot, redundant power support
Optional GBIC Transceivers
DGS-701 For 1000BASE-SX, multi-mode fiber, 550 m max.
DGS-702 For 1000BASE-LX, single-mode fiber, 5 km max.
DGS-703 For 1000BASE-LX, single-mode fiber, 10 km max.
DGS-704 For 1000BASE-LX, single-mode fiber, 30 km max.
DGS-708 For 1000BASE-LX, single-mode fiber, 70 km max.
DGS-711 For 1000BASE-T, Cat. 5 cable, 100 m max.
Optional Redundant Power Supply
DPS-200 Redundant power supply
DPS-900 8-slot redundant power supply chassis
Optional Port Module
DES-332GS 1 stacking port + 1 GBIC port
DES-132 2 10/100Mbps ports
DES-131F 1 100BASE-FX multi-mode fiber port (SC connector)
DES-132F 2 100BASE-FX multi-mode fiber ports (SC connectors)
DES-131FL 1 100BASE-FL single-mode fiber port (SC connector)
DES-132FL 2 100BASE-FL single-mode fiber ports (SC connectors)
DES-132G 2 1000BASE-SX Gigabit fiber ports (SC connectors)
DES-132GL 2 1000BASE-LX Gigabit fiber ports (SC connectors)
DES-132T 2 10BASE-T/100BASE-TX/1000BASE-T Gigabit copper ports
DES-132GB 2 GBIC-based ports
