Tanımlama
48 10/100Mbps Ports for Workstation Connection
The switch provides 48 10/100Mbps ports supporting auto-sensing and auto-negotiation of network speeds and full/half duplex. These ports can connect to workstations and print servers, giving each a dedicated bandwidth. All ports support auto MDI/MDIX, allowing you to connect to workstations, servers, or other switches from any port without the need to change your usual straight-through twisted-pair cables.
Copper Gigabit for Servers
The copper Gigabit provides an inexpensive alternative solution to fiber-optic. Using your existing low-cost Cat. 5 copper twisted-pair wires as the transmission media, these ports allow you to instantly upgrade your servers to Gigabit capability without requiring you to install new, expensive fiber cables. The ports support 10/100/1000Mbps network speed auto-sensing, full/half duplex and auto MDI/MDIX.
2 Mini GBIC Slots for Flexible Fiber Connection
2 mini GBIC slots are provided for flexible fiber connection. You can select to install optional transceiver modules in these slots for 1000BASE-SX short/medium-distance or 1000BASE-LX long-distance fiber backbone attachment. Use of the mini GBIC will disable their corresponding built-in copper 10/100/1000Mbps copper connections.
Wire-speed IP Routing
The switch is designed for basic IP routing, with instant support for Windows, Unix and Internet environments. It provides wire-speed non-blocking switch fabrics with hardware-based packet filtering/forwarding. Packet routing is performed by on-board ASICs at speeds many times faster than CPU-based routers.
Seamless Integration
The DES-3350SR can be instantly integrated into any existing network for seamless integration of Layer 2 and Layer 3 packet switching. With multi-layer support for every port, you can start with Layer 2 switching, then upgrade to Layer 3 routing anytime by simply re-configuring the ports. You can flexibly segment the network into domains and sub-domains, using (1) subnet IDs and user IP numbers to route traffic, and (2) custom filters based on users' physical MAC addresses to filter extraneous traffic. At Layer 2, the switch uses auto-learned and user-defined MAC addresses to discard and forward packets. At Layer 3, it looks at the user-specified routing table to route packets to their destinations.
Ready for Multi-media Applications
With Priority Queues and IP multicast (IGMP snooping) support, Quality of Services (QoS) can be guaranteed for successful execution of delay-sensitive applications like video conference.
Flow Control to Prevent Packet Loss
The switch supports standard IEEE 802.3x Flow Control. Working in conjunction with buf fer overrun auto-detection, this full-duplex data transfer mode provides protection against possible data loss for 802.3x supported servers directly connected to the switch.
Port Trunks for Aggregated Bandwidths
With low cost per port, port trunking provides an easy and economical alternative solution for server connection to attain Gigabit bandwidth. Up to 8 10/100Mbps ports can be combined together to create a load-sharing aggregated bandwidth to a server.
Genel Özellikler
Number of Ports
- 48 auto-sensing 10/100Mbps ports
- 2 combo 10/100/1000Mbps/SFP mini GBIC slots
LED
- Power (per device)
- Console (per device)
- RPS (per device)
- Link/Act (per port)
Port Functions
- IEEE 802.3 10BASE-T/802.3u 100BASE-TX, 802.3ab 1000BASE-T standards
- Auto-sensing speed with ANSI/IEEE 802.3 NWay auto-negotiation
- Full/half duplex for 10/100Mbps speed
- Full duplex for 1000Mbps speed
- IEEE 802.3x Flow Control in full-duplex, back pressure in half-duplex
- MDI/MDIX auto-sensing per port
- 10BASE-T cables:
UTP Cat. 3, 4, 5 (100 m max.)
- 100BASE-TX, 1000BASE-T cables:
UTP Cat. 5 (100 m max.)
Software
IP Routing
- IP v4 support
- IP Fragmentation support
- Routing protocols supported:
Static routing
RIP-1, RIP-2
OSPF v.2
VLAN
- IEEE 802.1Q Tagged VLAN
- Number of VLANs: 255 per device (max.)
Spanning Tree
- 802.1D Spanning Tree compatible
- 802.1w Rapid Spanning Tree
Multicast
- IGMP v2
- IGMP Snooping
- DVMRP
- PIM-DM
Priority Queues (CoS)
- Standard: IEEE 802.1p
- Number of queues: 4
Traffic Classification (CoS)
Can be based on user-definable application types:
- TOS
- Diffserv (DSCP)
- MAC address
- IP address
- TCP/UCP port number
Access Control Security
- Port security
- 802.1x Port-based access control support
- 802.1x MAC-based access control support
- RADIUS client for 802.1x
- Multi-layer ACL (Access Control List) based on:
MAC Address Table
8K entries per device
MAC Address Learning
- Dynamic entries: automatic update
- Static entries: user-defined
Routing Table
2K entries per device
Layer 2 Packet Forwarding Rates (half duplex)
- Ethernet: 14,880 pps per port
- Fast Ethernet: 148,810 pps per port
- Gigabit Ethernet: 1,488,100 pps per port
Layer 3 Packet Forwarding Rate (half duplex)
10.1Mpps
Memory
64 MB SDRAM packet buffer
Management Methods & Standards
- SNMP management v.1, v .2c, v.3
- Web-based management (via web browser)
- RMON monitoring
- Telnet (up to 8 sessions)
- CLI (command line interface)
Management Security
Password enabled
MIBs
- MIB-II (RFC 1213)
- Bridge MIB (RFC 1493)
- RMON MIB (RFC 1757)
- RIP (RFC 1724)
- OSPF (RFC 1850)
- CIDR (RFC 2096)
- 802.1Q VLAN MIB (RFC 2674)
- IGMP MIB (RFC 2833)
- If MIB (RFC 2233)
- Ethernet-like MIB (RFC 2358)
- D-Link enterprise MIB
RMON Groups
1, 2, 3, 9 (Alarm, Statistics, History, Event)
IP Number Self-identification
- DHCP client
- Bootp client
Firmware Upgrade
TFTP
Console Port
DB-9 RS-232 DCE
Çözümler
Sipariş Bilgisi
10/100Mbps Layer 3 Switch
DES-3350SR 48 10/100Mbps ports, 2 combo, 10/100/1000Mbps/SFP mini GBIC slots, redundant power support
Optional GBIC Transceiver
DEM-310GT For 1000BASE-LX, single-mode fiber, 10 km, max., 3.3V
DEM-311GT For 1000BASE-SX, multi-mode fiber, 550 m, max., 3.3V
Optional Redundant Power Supply
DPS-200 Redundant power supply
