Hızlı Arama
Ürün Özellikleri:
L2 Modular access switch
EOL
Tanımlama:
As a CO (central office) devices, this switch provides Ethernet Over VDSL (EoVDSL) access to the CPE (consumer premise equipment) such as the EoVDSL modems from the subscribers in the multi-unit, multi-tenant buildings. This switch connects to the service provider's public optical network (PON) through its Gigabit Ethernet fiber interfaces. The switch thus provides the last-mile connection by extending the public high-bandwidth network to people living and working in business parks, apartments, dormitories, campus and hospitals.
This switch has 14 slots, where first 2 slots (CPU-A and CPU-B) are used to install management modules. You configure the switch with a single management module, or 2 management modules for redundancy backup. The remaining slots can be used to install EoVDSL modules, with the port density able to reach 288 ports per switch.
You can also configure this switch with both EoVDSL and Fast Ethernet modules. This configuration gives you connections to both EoVDSL CPE (modems) and LAN workstations. Gigabit uplinks to the service provider side or to the PON are through the GBIC slots provided on the management modules. LAN server connections can also be through these GBIC slots.
Modules for EoVDSL installation are:
- Management module, with CPU, management agent, memory, a console port and an SNMP out-band management port for control of the switch. This module also provides 6 GBIC slots for Gigabit uplinks.
- EoVDSL module, with 24 EoVDSL ports through 1 RJ-21 (Telco-50) connector . 24 EoVDSL to POTS splitters are built into this module, eleminating for you the need to install separate splitters. Connections to PSTN is through another RJ-21 connector on the module.
- Power supply module. Each power supply module provides power for up to 10 EoVDSL modules. If you install 12 EoVDSL modules, you'll need 2 power supply modules. An additional power supply module can also be installed for redundant power backup, bringing the number of power supply modules up to 3 in this configuration.
- External power supply. An alternative to installing power supply modules in the chassis is to connect the switch to external power supplies. Up to 3 such power supplies can be connected.
For a mixed EoVDSL/LAN configuration, you can additionally select from the following modules:
- 10/100Mbps module, with 24 10/100Mbps ports (24 RJ-45).
- 100BASE-FX module, with 24 Fast Etherent fiber ports (SFF connectors).
Ürünler | Destek  | Haberler  | Hakkında |
