Tanımlama
Get the blazing speed of Gigabit Ethernet with the D-Link DGS-1008T, an 8-port 10/100/1000Mbps Switch that delivers power, performance, and reliability in one cost-effective, space-saving design. Increase the speed of your network server and backbone connections, or make Gigabit to the desktop a reality. Power users in the home, office, workgroup, or creative production environment can now move large, bandwidth-intensive files faster. Transfer graphics, CGI, CAD, or multimedia files across the network instantly. The versatile and compact 1U height design of the DGS-1008T enables the device to rack-mounted in a standard 19 inch rack, while conserving valuable rack space.
Advanced Switching Features
It features a non-blocking switching architecture that filters and forwards packets at full wire-speed for maximum throughput. An 8,000 MAC address table provides scalability for even the largest networks. Address learning and aging, 802.3x Flow Control for full duplex mode, and back pressure flow control for half-duplex mode alleviates traffic congestion and ensures reliable data transmission. Designed using industry standards, it is compatible with virtually all 10, 100, and 1000Mbps Ethernet devices and other vendor equipment. It protects your existing network investments while providing you with a straightforward migration path to faster Gigabit speeds.
Easy to Install and Maintain
The auto features of this switch make installation plug and play and hassle-free. No configuring is required. Auto MDI/MDI-X crossover on all ports eliminate the need for crossover cables or uplink ports. Auto-negotiation on each port senses the link speed of a network device (either 10, 100, or 1000 Mbps) and intelligently adjusts for compatibility and optimal performance. It also features diagnostic LEDs which display status and activity, allowing you to quickly detect and correct problems on the network.
Genel Özellikler
Standards
- IEEE 802.3ab 1000BASE-T
- IEEE 802.3u 100BASE-TX
- IEEE 802.3 10BASE-T
Protocol
CSMA/CD
Data Transfer Rate
- Ethernet: 10Mbps (half-duplex), 20Mbps (full-duplex)
- Fast Ethernet: 100Mbps (half-duplex), 200Mbps (full-duplex)
- Gigabit Ethernet: 2000 Mbps (full duplex)
Topology
Star
Network Cables
- Ethernet: 2-pair UTP Cat. 3,4,5 , EIA/TIA- 568 100-ohm STP
- Fast Ethernet: 2-pair UTP Cat. 5, EIA/TIA-568 100-ohm STP
- Gigabit Ethernet: 4-pair UTP Cat. 5, EIA/TIA-568 100-ohm STP
Çözümler
Sipariş Bilgisi
DGS-1008T 8-Port 10/100/1000Mbps Gigabit Ethernet Switch
