KVM-140EOL EOS
8-port KVM switch
Tanımlama
The D-Link 8 Port Rack Mount KVM Switch is a local remote management solution which allows you to easily control up to 8 PCs from a single console, allowing you to save time, physical space, and the cost of buying multiple keyboards and monitors.
Versatile Management
Toggle between clients using the front panel buttons or through keyboard hotkeys. A convenient Auto-Scan function allows you to automatically toggle between multiple computers sequentially at preset intervals. The front panel LEDs assist with workstation/server status monitoring. Green LEDs indicate that systems are online, while separate red LEDs indicate when a particular system has been selected for management via console.
Convenient Installation
The sturdy metal chassis is mountable in a standard 19” rack. Target workstations can be connected via keyboard/mouse. A PS/2 keyboard is emulated on each terminal allowing all attached computers to successfully boot without keyboard errors. Hotpluggable connections allow you to add devices to or remove them from the D-Link KVM-140 8 Port Rack Mount KVM switch without the need to shut it down.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
KVM-140
Back view
Front view
İndir
Destek Merkezi
