DKVM-IPVUCBEOL
KVM cable for connecting keyboard, mouse, and monitor
Tanımlama
Cable KVM 1.8 m designed to connect a keyboard, monitor and mouse, and is compatible with switches KVM over IP DKVM-IP8. DKVM-IPVUCB - cable set two-in-one that includes on one side a VGA cable (with 15-pin HDD connectors "plug") to connect to the computer video card, USB 2.0 cable (with USB connector) for connection to a USB port on your computer and on the other hand SPHD connector (Single connector for keyboard, mouse and monitor) to connect to DKVM-IP8. Cable DKVM-IPVUCB is a cable "all-in-one" and allows you to save space on your desktop by combining multiple cables in a bundle. Each cable is color-coded (PC99), which guarantees the correct connection.
