DKVM-4KEOL
4-Port PS/2 KVM Switch
Tanımlama
The D-Link DKVM-4K 4-port PS/2 KVM switch allows you to manage up to four computers with one monitor, one keyboard and one mouse. The DKVM-4K requires no driver installation and no external power adapter connection. This KVM switch supports hot-plugging - you don't need to turn your computers off before installing the device. The DKVM-4K allows you to switch between computers quickly and easily using the buttons located on the top panel or keyboard hot keys. The  DKVM-4K supports autoscan mode, which provides automatic switching to the next PC after the scan interval expires.
Genel Özellikler
| B | A | |
| Hardware | ||
| Ports for connecting KVM cables | • 4 VGA ports | • 4 VGA ports • 4 PS/2 ports (keyboard) • 4 PS/2 ports (mouse) |
| Ports for connecting management console | • Monitor (local): VGA • Keyboard (local): PS/2 • Mouse (local): PS/2 | |
| KVM cable connectors for connecting PC | • Video: 15-pin HDB connector (blue) (VGA) • Keyboard: 6-pin mini-DIN connector (purple) (PS/2) • Mouse: 6-pin mini-DIN connector (green) (PS/2) | |
| LEDs | • 4 port LEDs for connected PCs | |
| Buttons | • 4 port switching buttons | • 1 port switching button |
| Enclosure | • Plastic | |
| Connected PCs | • Up to 4 | |
| Autoscan mode | • Yes | |
| Switching between PCs | • Switching buttons on the top panel • Hot keys | |
| Sound notification of switching | • Yes | |
| Max. resolution | • 2048x1536 | |
| Dimensions (L x W x H) | • 100 x 65 x 25 mm | • 178 x 105 x 30,5 mm |
| Weight | • 725 g | • 272 g |
| Power Supply | • From PS/2 keyboard port on PC (no external power adapter required) | |
| Temperature | • Operating: 0° to 50°C • Storage: -20° to 60°C | |
| Humidity | • 0% to 80% non-condensing | |
| Optional Accessories | ||
| KVM Cables* | • DKVM-CB/1.2M/B • DKVM-CB/B • DKVM-CB3/B • DKVM-CB5/B | • DKVM-CB/A • DKVM-CB3/A • DKVM-CB5/A |
*Note: KVM Cables of B hardware version are compatible only with the DKVM-4K KVM switch of B hardware version. KVM Cables of A hardware version are compatible only with the DKVM-4K KVM switch of A hardware version.
Çözümler
Sipariş Bilgisi
DKVM-4K 4-Port PS/2 KVM Switch
