Hızlı Arama
Ürün Özellikleri:
Cable Modem DOCSIS / EuroDOCSIS 2.0 1-port 10/100BASE-TX Fast Ethernet and USB 1.1 interface
Genel Özellikler:
Fiziksel Özellikler
Device Interfaces
+ Compatible with DOCSIS / EuroDOCSIS 2.0
+ Compatible with DOCSIS / EuroDOCSIS 1.1
+ Compatible with DOCSIS / EuroDOCSIS 1.0
+ IEEE 802.3/802.3u 10/100BASE-TX Ethernet
+ USB 1.1 Type B
Interface
+ Ethernet-port 10/100BASE-TX (Auto-MDI / MDIX)
+ USB-port + Coaxial CATV, type "mother"
Data transfer rate: Downstream
+ Demodulation: 64/256QAM
+ Max. speed: 38Mbit / s (64QAM) .43 Mbit / sec (256QAM)
+ Frequency range: 91 to 857 MHz ± 30 kHz (accuracy)
+ Bandwidth: 6 MHz
+ Signal level: from-15dBmV to 15dBmV (modem automatically controlled gain )
 Data Transfer Rate: Upstream
+ Modulation: 64/256QAM
+ TDMA: QPSK, 8QAM, 16QAM, 32QAM, 64QAM, 128QAM
+ Max. speed: 320, 640, 1280, 2560 5120Kbit / s (16QAM)
+ Frequency range: 5 to 42MGts (including the boundary values)
+ Bandwidth: 0.2, 0.4, 0.8, 1.6, 3.2 MHz
+ TDMA: 200, 400, 800, 1600, 3200 and 6400KGts
+ S-CDMa: 1600, 3200 and 6400KHz Power
+ Power Input: 5V, 1.2A power adapter
+ Power Consumption: 5 Watts (standby), 6W (operating) Supported OS
+ Windows XP/Vista/7 (Ethernet and USB)
+ Mac OS (Ethernet only)
+ Unix / Linux (only Ethernet)Supported Protocols
+ Protocol: ICMP / SNMP V1, V2c, V3
+ MIB: MIB II / MCNS MIB Diagnostic Lights
+ Link / Activity Status
+ Online
+ Upstream Downstream
+ Power
Ürünler | Destek  | Haberler  | Hakkında |
