DPN-6608
GPON OLT switch Layer 2 8-port GPON SFP Downlink, 4-port and 2-port 1G/SFP 10G/SFP + UPLINK
Nereden Alınır
Tanımlama
GPON service provides data rates up to 2.54 Gb / s fiber-optic links and support the next generation of services for the simultaneous transmission of voice, video and data services, including high-speed Internet access and video streaming. DPN-6608 provides a cost-effective technology infrastructure deployment easy, ideal for high-rise buildings (MxU), for example, hotels, educational institutions, etc.
OLT performs the function of converting the interface GPON (Gigabit Passive Optical Network), compliant with the ITU-984.x, the interface of the main channel. OLT provides 4 interfaces 1G/SFP and 2 10G/SFP + interface as a trunk interface and supports Layer 2 features. DPN-6608 is equipped with 8-port OLT-optical modules for SFP, and each GPON interface allows you to connect up to 64 devices ONT through the optical splitter.
Genel Özellikler
Fiziksel Özellikler
Management port
• Console port RJ-45
• Port Control Out-of-band RJ-45
Gigabit Ethernet Uplink Ports
• 4 combo ports 1G mini-GBIC (SFP)
• 2 combo ports 10G mini-GBIC (SFP +)
• 2-port 10/100/1000BASE-T
• Fully compatible with IEEE802.3
• Fully compatible with IEEE802.3u
• Fully compatible with IEEE802.3z
• Fully compatible with IEEE802.3ab
• Support operations in full-duplex mode
• Supports IEEE 802.3x flow control for full-duplex
Port GPON OLT Downlink
• 8 OLT-SFP ports with SC-type connectors
• Fully compatible with ITU-984.2
• Each port supports OLT-64 ONT
• Speed ​​up to 2.54 / 1.25 Gb / s downstream / upstream
• Cable: single-mode fiber-optic cable
• Wavelength of the upstream (ONT-> OLT): 1310
• Wavelength for Downstream (OLT-> ONT): 1490 nm
Software features
Basic
• Auto Discovery / Grant Allocation / Ranging / Report Handling
• Reports of abnormal situations (Mode Dying Gasp / No connection / Deviation)
• Information OAM
• Bandwidth control for downstream through the limiter
• Bandwidth management for upstream by DBA
• Remote diagnostics (Loop back / Ping) 8
• Management of Peer to peer (access control / traffic shaping)
QoS
• Number of queues per port: 8 queues
• Supports 802.1p
• Limiting the speed of incoming traffic on port
• Strict Priority and WRR
Layer 2 functions
• 802.1Q VLAN (4K VLAN)
• Double tagging 802.1ad
• Link Aggregation (IEEE802.3ad (static / dynamic)) (for port uplink)
• Multicast VLAN
Safety
• MAC-Authentication
Management
• Access control lists (ACL)
• Telnet
• SYSLOG
• NMP v1, v2c
• Command Line Interface (CLI)
• RTC
• TFTP-client
• TFTP
• Web-interface
Power supply
• Support for optional external redundant power supply: DPS-500
• Power consumption: Max. 80 W
Size
• Width - 441 mm
• Height - 66 mm (1U)
• Length - 430 mm
Operating temperature
• 0 ° to 45 ° C
Storage temperature
• -40 ° to 70 ° C
Humidity
• 5% to 95% (non-condensing)
Certificate of EMI
• CE
Safety Certification
• CE + VCCI
Çözümler
Sipariş Bilgisi
Görseller
DPN-6608
Front view
İndir
Destek Merkezi
