DSM-320RDEOL EOS
Tanımlama
The D-Link MediaLounge DSM-320RD is a wireless media player with DVD and card reader that connects your home entertainment center to your home network. It allows you to wirelessly stream music, photos and videos from the PC to your television and stereo system. Using the 802.11g wireless technology , the DSM-320RD can stream media content from your PC at a high wireless signal rate or via an Ethernet cable. Experience digital media like never before with the MediaLounge DSM-320RD Wireless Media Player with DVD and Card Reader. The DSM-320RD provides instant access to digital music, videos, and photos all from the comfort of your living room.
The DSM-320RD integrates seamlessly with your existing wired or wireless network. Using progressive scan technology, you can watch your favorite DVD in high resolution (for high-definition and HD-ready TVs) with theater-like sound. In addition to DVD, this DVD Player also plays SVCD, VCD, CD-R, DVD-RW, CD-RW, CD, and MP3 discs. The DSM-320RD features a built-in 5-in-1 card reader, which provides a convenient way to view and share digital photos, music, and videos stored on a memory card. Popular memory cards, including SD, Memory Stick, MMC, and Compact Flash (Type I and II) are supported. You can get access to thousands of songs right from your living room. With support for Windows Media Connect (WMC) music files protected by Windows Media Digital Rights Management (WMDRM) can be streamed from your PC to your living room.
Setting up the DSM-320RD is simple, and with support for Windows Connect Now, configuring the wireless settings is easier than ever before. Simply run the Wireless Network Setup Wizard from Windows XP Service Pack 2 and transfer the wireless settings to the DSM-320RD using a USB flash drive.
Genel Özellikler
Ağ
• 802.11g standardı hızları 54 Mbps'e kadar *
• 802.11b ağları 11 Mbps hızlarda **
• Port 10/100Base-TX Hızlı Ethernet
• Destekler DHCP ve statik IP adresi
Ağ Protokolü
TCP / IP
Aktarım protokolü medya akışları
HTTP
Desteklenen disk formatları
VCD DVD, SVCD, CD-R, CD-RW, DVD-RW, CD-MP3
Desteklenen medya depolama
SD, Compact Flash (I ve II), MMC, Memory Stick
Sonuçlar
• RCA / AV ses konnektörleri
• RCA / AV Video konektörleri
• S-video
• Komponent video 5.1 kanal
• Optik dijital ses kanal ses desteği
• Koaksiyel dijital ses kanalı
Desteklenen medya biçimleri
• Ses formatları: MP3, WAV ve AIFF (sadece PCM), WMA, Ogg Vorbis
• Resim formatları: JPEG (Grayscale, RGB, sadece YCbCy), JPEG 2000, BMP (sıkıştırılmamış), PNG, TIFF (sadece RGB), GIF
• Video formatları: MPEG1/2/4, MP3 veya PCM ile XVID,
• AVI (sadece MPEG4)
Özelleştirmek
• UPnP AV 1.0
•Intel NMPR ile uyumlu
Kablosuz Anten
2.4 GHz frekansı ile 2dBi bir kazanç ile monopol anten Döner Frekans bandı
2.5 GHz 2.4 GHz arasında
Anten empedansı
50 Ohm
Kablosuz güvenlik
• WEP 64/128 bit şifreleme
• WPA-PSK
