DCS-7413Proje
Full HD camcorder with the possibility of night shooting for outdoor use
Nereden Alınır
Tanımlama
Full HD camcorder with the possibility of night shooting for outdoor use D-Link DCS-7413 is the ideal solution for creating a system of professional high-definition video, and security for small, medium and large enterprises. Megapixel high-sensitivity CMOS-sensor with progressive scan provides excellent image quality in various lighting conditions. Compact design "all in one" makes the camera ideal for safe installation and requires no additional accessories.
High Quality Video
To maximize bandwidth efficiency and higher image quality, DCS-7413 compresses the video in real time using the MPEG-4 codec and MJPEG, and H.264, which creates a low resolution image and makes it suitable for continuous recording high detail or for use in networks with low bandwidth. Furthermore, DCS-7413 supports three separate profiles for simultaneous transmission of video in real-time recording. This property provides a wide range of applications for security cameras, for example, observation of public spaces for the detection of incidents and coordinating the response, control of restricted areas, deterring criminal activity or surveillance assets. Moreover, the bandwidth requirement can be adjusted in real time on the network and stored video files can be stored on a network storage device (NAS) or card SD.
Continuous monitoring
Built-in IR LEDs turn on automatically depending on the lighting conditions, allowing the camera to record videos even in low light or darkness. This feature allows the camera to record clear color images during the day and black-and-white image in low light conditions. DCS-7413 can detect moving objects in total darkness at a distance of 30 meters. Equipped with a powerful integrated circuit, the camera provides video compression in real-time formats, H.264, MPEG-4 and MJPEG. The combination of these elements makes the DCS-7413 an ideal solution for day and night surveillance.
Reliable management software
As with the camera DCS-7413 includes software D-ViewCam - ready set video surveillance software that lets you view images, manage, and to record up to 32 cameras on a single computer. Video recording and email alerts can be triggered by motion or by triggering events from digital input devices, informing administrators of unusual activity.
Connectivity
Camera DCS-7413 is equipped with built-in PoE standard 802.3af, simplifying installation by providing a supply and connection to the network using one Ethernet-cable, and thus eliminating the need for drilling holes and laying of additional power cables. In addition, the digital inputs and outputs allow you to connect external devices such as IR sensors, switches and signal relay
Genel Özellikler
Fiziksel Özellikler
Camera Hardware Profile
• 1/2.7" 2 Megapixel progressive CMOS sensor
• 30 meter IR illumination distance
• Minimum illumination: 0 lux with IR LEDs on
• Built-in Infrared-Cut Removable (ICR) Filter module
• 10x digital zoom
• Focal length: 4.3 mm
• Aperture: F2.0
• Angle of view:
  (H) 73.5°
  (V) 42.5°
  (D) 83.3°
Camera Housing
• IP-66 compliant weatherproof housing
• Cable management bracket
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• Configurable privacy mask zones
• Configurable shutter speed, brightness, saturation, contrast, and sharpness
Video Compression
• Simultaneous H.264/MPEG-4/MJPEG format compression
• H.264/MPEG-4 multicast streaming
• JPEG for still images
Video Resolution
• 16:9 at 1920 x 1080 (up to 15 fps), 1280 x 720, 800 x 450, 640 x 360, 480 x 270, 320 x 176, 176 x 144 up to 30 fps
• 4:3 at 1440 x 1080 (up to 15 fps), 1280 x 960, 1024 x 768, 800 x 600, 640 x 480, 320 x 240, 176 x 144 up to 30 fps
Audio Support
• G.726
• G.711
External Device Interface
• 10/100 BASE-TX Fast Ethernet port with support for 802.3af PoE
• SD/SDHC card slot
• SD/SDHC card slot
• Audio input/output
• DI/DO Connector 12 V DC Output
Network Protocols
• IPv6
• IPv4
• TCP/IP
• UDP
• ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• DDNS client (D-Link)
• SMTP client
• FTP client
• HTTP/HTTPS
• Samba client
• PPPoE
• UPnP port forwarding
• RTP/RTSP/RTCP
• IP filtering
• QoS
• CoS
• Multicast
• IGMP
• ONVIF compliant
Security
• Administrator and user group protection
• Password authentication
• HTTP and RTSP digest encryption
System Requirements for Web Interface
• Browser: Internet Explorer, Firefox, Chrome, or Safari
Event Management
• Motion detection
• Event notification and uploading of snapshots/video clips via e-mail or FTP
• Supports multiple SMTP and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Take snapshots/video clips and save to local hard drive or NAS via web browser
• Configuration interface accessible via web browser
Operating System
• Windows 7/Vista/XP/2000
D-ViewCam™ System Requirements
• Operating System: Microsoft Windows 7/Vista/XP
• Web Browser: Internet Explorer 7 or higher
• Protocol: Standard TCP/IP
D-ViewCam™ Software Functions
• Remote management
• Control and manage up to 32 cameras
• View up to 32 cameras on one screen
• Management functions provided in web interface
• Scheduled motion triggered and manual recording
Fiziskie raksturlielumi
Weight
• 1.92 kg with bracket and sun shield
External Power Adapter
• Input: 100 to 240 V AC, 50/60 Hz
• Output: 12 V, 1.25 A
Power Consumption
• 11.2 watts ± 5 %
Temperature
• Operating: -40° to 50°C
• Storage: -20° to 70°C
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• FCC
• C-Tick
Dimensions
Çözümler
Sipariş Bilgisi
Görseller
DCS-7413
Front view
View from the right
Left side view
İndir
Destek Merkezi
