DIB-200EOL EOS
Adapter StreamTV
Tanımlama
Adapter StreamTV DIB-200 - a compact device that allows you to view media content on a high definition big screen. With this adapter, you can watch HD-video display or projector to display the media content from the Internet to the TV, or play music library without using a wired connection.
Full HD support, and other features
Powerful processor adapter DIB-200 is capable of decoding high-definition video at resolutions up to 1080p, delivering a crisp, highly detailed HD-image to any compatible display. DIB-200 supports popular video formats H.264, MPEG4 and WMV, as well as the image format JPEG, allowing you to watch movies or photos on the big screen with high detail. The adapter also supports audio formats MP3 and WMA, allowing you to connect your TV to the audio system for listening to digital music library.
The freedom of movement provided by the wireless network
StreamTV adapter uses high-speed wireless technology for streaming media content from your device to the big screen. This eliminates the need for cables and provides the ability to control the playback of video and music from your couch or moving the device around the house. The compact form factor of the device allows you to arrange a viewing of media content on HDMI-display anywhere. All that is required - is the presence of the display and the network of Wi-Fi.
Simple streaming using DLNA-applications
All that is required - is a mobile device and any of the many applications that can transmit streaming media content to DLNA-enabled devices. Use these apps to play music collection or media content from the Internet on your TV. The adapter sends StreamTV streaming media content from the device through a wireless router, during the playback of content can minimize the application and return to the use of mobile devices in the usual way, ie browse Web-sites, check e-mail and play games.
Quick and easy setup
Setting the DIB-200 is executed in a few simple steps thanks to an intuitive interface for mobile devices. After you configure the adapter to the wireless network, open a DLNA-app and start viewing content. New devices connected to the network Wi-Fi, will automatically detect the adapter StreamTV and prepared for use, no need to connect each device individually.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DIB-200/Bx
Front view
İndir
Destek Merkezi
