DIB-200
Adapter StreamTV
Nereden Alınır
Tanımlama
Adapter StreamTV DIB-200 - a compact device that allows you to view media content on a high definition big screen. With this adapter, you can watch HD-video display or projector to display the media content from the Internet to the TV, or play music library without using a wired connection.
Full HD support, and other features
Powerful processor adapter DIB-200 is capable of decoding high-definition video at resolutions up to 1080p, delivering a crisp, highly detailed HD-image to any compatible display. DIB-200 supports popular video formats H.264, MPEG4 and WMV, as well as the image format JPEG, allowing you to watch movies or photos on the big screen with high detail. The adapter also supports audio formats MP3 and WMA, allowing you to connect your TV to the audio system for listening to digital music library.
The freedom of movement provided by the wireless network
StreamTV adapter uses high-speed wireless technology for streaming media content from your device to the big screen. This eliminates the need for cables and provides the ability to control the playback of video and music from your couch or moving the device around the house. The compact form factor of the device allows you to arrange a viewing of media content on HDMI-display anywhere. All that is required - is the presence of the display and the network of Wi-Fi.
Simple streaming using DLNA-applications
All that is required - is a mobile device and any of the many applications that can transmit streaming media content to DLNA-enabled devices. Use these apps to play music collection or media content from the Internet on your TV. The adapter sends StreamTV streaming media content from the device through a wireless router, during the playback of content can minimize the application and return to the use of mobile devices in the usual way, ie browse Web-sites, check e-mail and play games.
Quick and easy setup
Setting the DIB-200 is executed in a few simple steps thanks to an intuitive interface for mobile devices. After you configure the adapter to the wireless network, open a DLNA-app and start viewing content. New devices connected to the network Wi-Fi, will automatically detect the adapter StreamTV and prepared for use, no need to connect each device individually.
Genel Özellikler
Fiziksel Özellikler
Device Interfaces
• IEEE 802.11n/g/b
• HDMI (Type A)
• Micro USB (for power input)
Standards
• DLNA
• IEEE 802.11b
• IEEE 802.11g
• IEEE 802.11n
• HDMI
• Wi-Fi Miracast 1
Minimum Requirements
• TV, monitor or other display with an HDMI type A
• Mobile device with iOS or Android 2
Supported Formats 3
• Video: H.264, MPEG4, WMV
• Audio: MP3, WMA
• Picture: JPEG
Fiziksel Özellikler
Measurements
60 x 37 x 14 mm
Weight
20 grams
Power
Entry: 2.5 W via USB
Temperature
• Operating: 0 to 40 C
• Storage: -20 to 65 C
Humidity
• Operating: 0% to 90% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certifications
• DLNA
• CE
• Certified WiFi 4
• FCC
1 Wi-Fi Miracast requires a mobile device that supports Wi-Fi Miracast.
2 application settings for this device requires iOS 5.0 or later, or Android 4.0 or higher. Devices with earlier versions of the operating systems might be capable of transmitting streaming media content on the DIB-200, but they will not support an application required for the initial setup.
3 can be installed additional codecs that satisfy the requirements of the regional licensing.
4 This device can be certified Wi-Fi, if it is needed.
Çözümler
Sipariş Bilgisi
Görseller
DIB-200
Front view
İndir
Destek Merkezi
