Hızlı Arama
Ürün Özellikleri:
Internet Camera
EOL EOS
Genel Özellikler:
Video Specifications
Resolution
640 x 480 pixel
Sensor
1/3" color CMOS sensor
Gain control
Automatic
Exposure
Automatic
White Balance
Automatic
Shutter
Electronics 1/60 ~ 1/15000 secretary
Minimum Illumination
2.5lux@f1.4, 3000K Color
Focal Length
6.0 mm
Aperture
F=1.8
Focus Extent
20 cm -
Lens mounting
Fixed board lens, CS-mount type
Image (Video Setting)
Image compression
JPEG
Frame rate
30fps@QCIF, 20fps@CIF , 3fps@VGA
Compression Rate selection
5 level (Very Low, Low, Medium, High, V ery High)
Frame rate setting
1, 5, 7, 15, 20, auto (depends on the video format)
Video resolution
160x120, 320x240, 640x480
Brightness control
Range 1- 128
Contrast control
Range 1- 128
Hue control
Range 1- 128
System Hardware
LAN Connector
One RJ-45 port to connect to 10/100Mbps Ethernet, auto-sensed, wireless
Wireless LAN (DCS-1000W only)
Built-in 802.11b wireless LAN module (Wi-Fi   compliant)
Wireless LAN Modulation Techniques (DCS-1000W only)
Direct Sequence Spread Spectrum (DSSS)
Wireless LAN Frequency Range (DCS-1000W only)
2.4 - 2.497GHz
Transmitter Output  Power (DCS-1000W only)
12dBm
Generic I/O Port
4 I/O ports, 2 for input, and 2 for output
LED Indicator
-  Power LED (Blue)
-  LAN/WLAN Activity LED (Orange)
Slide Switch
LAN/LAN&WLAN/WLAN
Antenna Connectors
2 connectors (DCS-1000W only)
Communication Support
Wireless LAN Encryption
64 bit, 128 bit or OFF
Communication Protocols
HTTP, FTP , TCP/IP, UDP , ARP ,  ICMP,  BOOTP , RARP, DHCP , PPPoE
System Requirements
Browser Support
-  Internet Explorer 5.0 or above (ActiveX & JAV A Mode - View Image for windows
   OS and JAV A Mode-View Image for other OS)
-  CPU:  Pentium II, 266 MHz or above
-  Memory Size:  32 MB (64 MB recommended)
-  VGA card resolution:  800x600 or above
-  Netscape 6.0 or above (JAV A Mode - View  Image)
IPView Application
-  Win 98, Win 98 SE, Win 2000, Win Me, Win XP
-  Pentium III, 450 MHz or above
-  Memory Size of 128 MB (256 MB Recommended)
-  VGA card resolution of 800x600 or above
Fiziksel Özellikler
Power Supply
DC 5V/2.4A, switching type
Power Communication
6.5 Watt (1300mA x 5V)
Weight
280 gram
Operating temperature
5  C  ~  50  C
Storage temperature
-25  C  ~  50  C
Humidity
5%  ~  95% non-condensing
EMI Certification
- DCS-1000W: FCC Class A,  CE Class A
- DCS-1000: FCC Class B, CE Class B
Ürünler | Destek  | Haberler  | Hakkında |
