Tanımlama
POWERFUL 24 HOUR SURVEILLANCE
D-Link’s DCS-6410 Day & Night PoE Dome Network Camera is designed for round-the-clock surveillance. A CCD (Charged-coupled Device) sensor delivers high-quality images without distortion, while mounted infrared LEDs allow for nighttime monitoring over distances of up to 49 feet (15 meters). These elements make the DCS-6410 an ideal camera for indoor surveillance applications in homes, offi ces and business facilities.
HIGH-QUALITY VIDEO MONITORING
The DCS-6410 supports simultaneous dual-streaming for live monitoring and recording, and delivers excellent video quality. Embedded with a powerful SoC (System-on-Chip), the camera provides high-quality, real-time video compression in MPEG-4 and motion JPEG formats. D-ViewCam, the free, bundled software capable of recording and displaying 32 channels allows you to reliably monitor and record high-quality images. Leverage the camera’s built-in Samba client to directly transfer images and videos to a NAS without the need for any additional hardware or software.
CLEAR, SHARP IMAGES FROM EVERY ANGLE
The dome-shaped DCS-6410 provides for greater viewing angles making it ideal for monitoring narrow spaces like elevators. The camera is capable of recording in MPEG-4 and motion JPEG compression with D1/CIF/QCIF resolution for smoother performance. Images are delivered at a maximum resolution of D1 at up to 30 frames per second.
SURVEILLANCE ON THE GO1
The DCS-6410 supports 3GPP mobile surveillance. A live feed from the camera can be accessed on a 3G cellular network using a compatible cell phone, PDA or any device capable of RTSP (Real Time Streaming Protocol) streaming. This enables you to monitor your home or offi ce space in real time even when you are on the go.
FLEXIBLE CONNECTIVITY
Power over Ethernet (PoE) connectivity allows for discreet installation in virtually any indoor location. For effective surveillance around any space, this camera’s built-in 802.3af compliant PoE module eases the installation process by reducing the need to lay additional cabling. In addition, the 10/100BASE-TX Ethernet port connects seamlessly to local network or to the Internet via a gateway router. The camera can be accessed and viewed from any network place as a device on the network. The DCS-6410 also features an RCA connector which can be integrated easily into your existing analog CCTV (Closed Circuit Television) system; helping you migrate from an existing analog security system to an IP-based solution.
EASY TO INSTALL AND EASIER TO MANAGE
The DCS-6410 can be mounted on a fl at surface or with a drop-ceiling bracket. Manage and monitor upto 32 cameras using D-Link’s D-ViewCam software. You can also set up automated e-mail alerts to be instantly informed of unusual activities. In addition, this network camera supports the Universal Plug-n-Play feature, which allows computers running on Windows XP/Vista to automatically recognize the camera and adds it to the network. Sign up with one of the free Dynamic DNS services available on the web, to assign a name and domain to the camera (for example, mycamera.dlinkddns.com). This allows you to remotely access the camera without having to remember the IP address.
Genel Özellikler
NETWORK PROTOCOL SUPPORT
TCP/IP, RTSP, RTP, RTCP, HTTP, SMTP, FTP, NTP, DNS, DHCP, UPnP, DDNS, PPPoE, ICMP, Samba client, 3GPP
BUILT-IN NETWORK INTERFACE
10/100BASE-TX Ethernet Port
LAN
+ IEEE 802.3 compliant
+ IEEE 802.3u compliant
+ IEEE 802.3af PoE compliant
+ Supports Full-Duplex operations
+ Supports 802.3x Flow Control support in Full-Duplex mode
CAMERA SPECIFICATIONS
+ Built-in 1/3-inch CCD sensor
+ Minimum Illumination:
- 0.1 lux @ F1.6 (typical)
- 0 lux (15 meter range with IR LEDs)
+ Lens: 4.3mm, F1.6
+ Resolution: 420 TV lines
+ AGC / AWB / AES
+ Electronic Shutter:
- NTSC: 1/60 ~ 1/100,000 sec
- PAL: 1/50 ~ 1/110,000 sec
+ IR LEDs (15 meter range)
+ Field Of View:
- 92.4° diagonal
- 55.3° vertical
- 73.1° horizontal
VIDEO FEATURES
+ Adjustable image size and quality
+ Time stamp and text overlays
+ Motion adaptive de-interlacing
+ 16x digital zoom
PAN AND TILT FUNCTIONS
+ Pan Range: 170° ~ -170° (manual)
+ Tilt Range: 60° ~ -15° (manual)
VIDEO RESOLUTION
NTSC support:
+ up to 30 fps at 176x120
+ up to 30 fps at 352x240
+ up to 30 fps at 704x480
PAL support:
+ up to 25 fps at 176x144
+ up to 25 fps at 352x288
+ up to 25 fps at 704x576
VIDEO ALGORITHM SUPPORT
+ Simultaneous MPEG4/MJPEG dual format compression
+ Simultaneous profi le support for web viewing, 3G mobile viewing and video recording
+ JPEG for still images
AUDIO
+ Sampling Rate:
- GSM-AMR: 12.20 Kbps
- PCM: 8 Kbps
+ Full duplex audio communication
LED INDICATORS
Link & Power
I/O CONNECTORS
+ 2 inputs
+ 1 output
PORT SUPPORT FOR EXTERNAL PT DEVICES
RS-485
MEMORY
+ SDRAM: 64 MB
+ Flash ROM: 8 MB
RESET BUTTON
Reset to factory default settings
SYSTEM REQUIREMENTS
Windows XP, Vista
REMOTE MANAGEMENT
+ Configuration is accessible via web browser
+ View and record video via web browser
SECURITY
+ Administrator and user group protected
+ Password authentication
D-VIEWCAM SOFTWARE FUNCTIONS
+ Remote management and control of up to 32 IP cameras
+ View up to 32 cameras on one screen
+ Supports all management functions provided in web interface
+ Scheduled motion triggered or manual recording options
OPTIONAL ACCESSORIES
External Speakers
Çözümler
Sipariş Bilgisi
DCS-6410 Day & Night PoE dome network camera
