Tanımlama
	High resolution Surveillance
	The D-link DCS-3710 is a high-end Megapixel Day & Night WDR Network Camera, equipped with a 1/3” Megapixel WDR progressive Scan CMOS and a 2.8~12 mm DC auto iris lens. The DCS-3710 captures video in both dark and light environments, or even subjects shot against a backlight by neutralizing and generating a realistic image. In addition, the removable IR-cut filter for day/night functionality provides clear details and high quality video at any hour of the day. The DCS-3710 incorporates power over Ethernet (PoE) and an SD card slot. Consequently, it can be easily installed in a variety of locations.
	Multiple video streams
	The DCS-3710 supports simultaneous streaming of MPEG-4 and MJPEG video to provide both high-quality, and bandwidth-efficient compression formats. MJPEG delivers excellent file integrity, ideal for situations which required high image detail. Mpeg-4 produces a small file size, making it more useful for extended recording or for use in low bandwidth networks. Additionally, the DCS-3710 supports multicast MPEG-4 streaming allowing users to view contact by subscribing to a multicast IP address on the network.
	Flexible Connectivity
	The DCS-3710 include input and output ports allowing connectivity to external devices such as IR sensors, switches, and alarm relays. It also comes with a RS-485 interface, providing connectivity to an optional pan/tilt enclosure, which effectively adds pan/tilt functionality to the DCS-3710. Additionally, a 12 V interface provides power for an optional LED illuminator.
	Wide dynamic range (WDR) applications
	the Wide Dynamic Range (WDR) function of a camera provides clear images even under backlit conditions where the intensity of illumination can vary significantly. the DCS-3710 is recommended for extreme high-contrast environments. For example, when placed indoors, the DCS-3710 will adjust itself to the intense sunlight that may be streaming in through a nearby window. this makes it an ideal solution for security applications.
Genel Özellikler
	General Specification
	• 1/3” Megapixel WDR progressive Scan CMOS
	• Removable IR-cut Filter: Auto/Schedule/Manual
	• 3A Control: AGC, AWB, AES
	• DC iris Vari-focal lens: 2.8~12 mm, F1.3
	• Min illumination:
	• Color 0.3 lux, B/W: 0.02 lux
	• WDR SN ratio: 100 db
	Audio
	• Two-way audio
	• External audio in
	• External audio out
	• G.726 Codec
	Video algorithms supported
	• Simultaneous dual stream supports (MPEG and MJPEG)
	• Simultaneous profile support for web viewing, 3g mobile viewing, and video recording
	• Jpeg compression for still images
	Video resolution
	• Supported resolutions: 1280 x 960 / 1280 x 720 / 640x480 / 320x240 / 160x120
	• Up to 30 fps to all resolutions
	Network connectivity
	• 802.3af power over Ethernet (PoE)
	• 10/100 Mbps Fast Ethernet auto Negotiation
	I/O connector
	• 4-pin auto iris lens connector
	• Di x 2
	• Do x 1
	• RS-485
	• 12 V DC, 200 mA Output
	• SD Slot
	Security
	• Administrator and user group protected
	• Password authentication
	Remote management
	• Camera confiscation and camera system log
	• Take snapshots and save to hard drive via a web browser
	• D-ViewCam™
	Networking protocols
	• IPv4, DHCP , ARP , DNS, TCP/IP , DDNS (D-LINK), HTTP , HTTPS, UPNP™ Port Forwarding
	• SAMBA, SMTP , PPPOE, NTP (D-LINK), FTP, RTP , RTSP , UDP , RTCP , ICMP , 3GPP
	System requirements for viewing
	• Internet explorer v6.0 or later
	System requirements to run D-ViewCam™
	• Operating System: Windows Vista ®, Microsoft Windows ® XP
	• Web browser: Internet Explorer v6.0 or later
	• Protocol: Standard TCP/IP
Çözümler
Sipariş Bilgisi
DCS-3710 Megapixel Day & Night WDR Network camera
