Hızlı Arama
Ürün Özellikleri:
High-speed PTZ dome network camera with 30x optical zoom
Tanımlama:
Powerful surveillance High speed dome PTZ camera DCS-6817 is perfect for office surveillance systems. Sensor Sony ¼ ” EX-View CCD delivers clear, crisp images. supports simultaneous monitoring and recording, and delivers excellent video quality. Embedded with a powerful SoC (System-on-Chip), the camera provides high quality video compression real-time MPEG-4 and MJPEG. Proportional speed of pan, tilt, and zoom Change speed pan and tilt proportional to optical zoom camera. If you increase the speed of rotation is automatically slowed to improve the review and handling. Preset PTZ presets allow the camera to control specified areas. Weatherproof enclosure for outdoor use The DCS-6817 is equipped with all-weather protected enclosure (IP66 standard). Built-in heater and fan allows camera to operate in extreme conditions at temperatures from -40°C to 50°C. Removable IR cut filter for continuous monitoring The infrared filter can be adjusted manually or set to automatically adjust based on lighting conditions. This feature allows the camera to capture crisp color images during the daytime and grayscale images in low light Management Control and view up to 32 cameras using software D-ViewCam D-Link. Users can configure automatic notification by e-mail for instant information on abnormal events. Wide dynamic range (WDR) Function (WDR) camera provides a clear image even when backlit, where the intensity of illumination can vary significantly. It is recommended to use the DCS-6817 high contrast in extreme conditions. For example, when you install the device inside, the camera adapts to intense sunlight falling from the window.
Ürünler | Destek  | Haberler  | Hakkında |
