DCS-6817EOL EOS
High-speed PTZ dome network camera with 30x optical zoom
Nereden Alınır
Tanımlama
Powerful surveillance High speed dome PTZ camera DCS-6817 is perfect for office surveillance systems. Sensor Sony ¼ ” EX-View CCD delivers clear, crisp images. supports simultaneous monitoring and recording, and delivers excellent video quality. Embedded with a powerful SoC (System-on-Chip), the camera provides high quality video compression real-time MPEG-4 and MJPEG. Proportional speed of pan, tilt, and zoom Change speed pan and tilt proportional to optical zoom camera. If you increase the speed of rotation is automatically slowed to improve the review and handling. Preset PTZ presets allow the camera to control specified areas. Weatherproof enclosure for outdoor use The DCS-6817 is equipped with all-weather protected enclosure (IP66 standard). Built-in heater and fan allows camera to operate in extreme conditions at temperatures from -40°C to 50°C. Removable IR cut filter for continuous monitoring The infrared filter can be adjusted manually or set to automatically adjust based on lighting conditions. This feature allows the camera to capture crisp color images during the daytime and grayscale images in low light Management Control and view up to 32 cameras using software D-ViewCam D-Link. Users can configure automatic notification by e-mail for instant information on abnormal events. Wide dynamic range (WDR) Function (WDR) camera provides a clear image even when backlit, where the intensity of illumination can vary significantly. It is recommended to use the DCS-6817 high contrast in extreme conditions. For example, when you install the device inside, the camera adapts to intense sunlight falling from the window.
Genel Özellikler
Fiziksel Özellikler
Camera features
• Sensor 1/4” EX-View CCD
• Optical zoom: 30X
• Focal length 3.4~102 mm
• Angle of view (horizontal): 2.2° ~ 60.8°
• Digital zoom: 12 X
• Day / Night: ICR
• 0.1 Lux (color); 0.01 Lux (B/W)
• 540 TVL
• Electronic shutter speed 1/1 ~ 1/10K sec
• Automatic gain control (AGC)
• Manual / auto focus (AF)
• Manual / auto exposure (AE)
• Manual / auto white balance(AWB)
• Back light compensation (BLC)
• Wide dynamic range (WDR)
Codec support
• JPEG for still image
• MPEG4/MJPEG dual format compression
Video resolution
Supports NTSC:
• Up to 30 fps at 176 x 120
• Up to 30 fps at 352 x 240
• Up to 30 fps at 720 x 480
PAL support:
• Up to 25 fps at 176 x 144
• Up to 25 fps at 352 x 288
• Up to 25 fps at 720 x 576
Video features
• Configurable size and quality
• Timestamp and text overlay
• Customizable window motion detector
Video bitrate
Up to 3 Mbps
Support network protocols
IPv4, ARP, TCP/ IP, UDP, ICMP, DHCP client, NTP client, DNS client, DDNS client, SMTP client, FTP client, HTTP server, PPPoE, UPnP
Built-in network interface
Port 10/100BASE-TX Ethernet
LAN
• Compliance with IEEE 802.3
• Compliance with IEEE 802.3 u
• Full duplex mode
• Access control 802.3 x for full duplex mode
I/O Port
• 8 alarm inputs
• 1 alarm output
Camera work
• Rotate 360°
• Tilt -10° ~ 190°
• Preset accuracy pan/tilt 0.225°
• Preset speed pan/tilt 5° ~ 400°
• 4 preset routes
• 4 preset auto-rotate
• 8 consecutive presets
• 16 privacy mask
• Mirroring
• Built-in heater and fan
• IP66 standard
• Protection from vandals
Surveillance software function
• Remote management/control of up to 32 cameras
• View up to 32 cameras on one screen
• Management functions through the web interface
• Schedule motion detection or manual recording
Remote control
• Configuration accessible via web browser
• Recording and saving quick snapshots/video via web browser
System recommendations
• Operating system: Microsoft Windows 2000, XP, Vista
• Browser: Internet Explorer 6.0 or higher
Fiziksel Özellikler
Weight
2.6 kg
Food
24 VAC
Power consumption
A maximum of 65 W (with heating)
Operating temperature
-40°to 50° C
Storage temperature
-20°to 70° C
Operating humidity
20% to 80% non-condensing
Certificates
• FCC
• CE
• RoHS
Optional mounting accessories
(not included in the camera kit)
DCS-80-5 / DCS-80-6
• Size: 187 x 147 x 76 mm
• Mounting surface: 187 x 147 mm
• Weight: 2 kg
DCS-32-1
• Height: 250 mm
• Diameter: 50 mm
• Weight: 1 kg
DCS-32-2
• Height: 500 mm
• Diameter: 50 mm
• Weight: 1.8 kg
DCS-32-3
• Dimensions: 348 X 104 X 138.6 mm
• Diameter: 45 mm
• Weight: 1.5 kg
DCS-32-4
• Dimensions: 204 x 124 x 135.2 mm
• Diameter: 44.5 mm
• Weight: 1.2 kg
Çözümler
Sipariş Bilgisi
The DCS-6817/B1 high-Speed PTZ dome network-camera with 30x optical zoom Optional accessories* The DCS-32-1 Arm length 50 cm, for mounting the network cameras DCS-6815, DCS-6817, DCS-6818 and the DCS-6915 on the ceiling The DCS-32-2 Bracket length 25 cm for installation of network cameras DCS-6815, DCS-6817, DCS-6818 and the DCS-6915 on the ceiling The DCS-32-3 Standard pendant for installation of network cameras DCS-6815, DCS-6817, DCS-6818 and the DCS-6915 on the wall The DCS-32-4 Mini pendant for installation of network cameras DCS-6815, DCS-6817, DCS-6818 and the DCS-6915 on the wall The DCS-80-6 power supply for external network cameras DCS-6815, DCS-6817, DCS-6818 and the DCS-6915
Görseller
DCS-6817
Front view
İndir
Destek Merkezi
