DCS-71PEOL EOS
7" Outdoor Dome Housing (PoE)
Nereden Alınır
Tanımlama
D-Link’s DCS-71 outdoor dome housing series provide cost-effective protection and versatile connectivity options for D-Link motorized pan and tilt surveillance cameras in outdoor environments. The DCS-71P model facilitates Power over Ethernet (PoE) while the DCS-71W provides wireless connection for the security camera, providing extra convenience in connecting and wiring surveillance cameras. A built-in power supply, heater and blower mean these housings can be used under adverse weather conditions.
Flexible Connectivity Options
The DCS-71P incorporates Power over Ethernet (PoE) in which electric power is transmitted over an Ethernet cable along with the Ethernet data. This allows the DCS-71P model to be easily installed in a variety of locations without the need for power cabling. The DCS-71W is equipped with wireless antennas that allow the camera to be controlled and monitored wirelessly. This avoids the need to install Ethernet wiring.
Weather-proof
Designed to be mounted outdoors, the DCS-71 housings feature an IP66 certified enclosure which protects against the elements including dust and heavy jets of water.
Genel Özellikler
Housing
Casing Material Aluminium Zinc Alloy
Cable Management Bracket
Yes
Wireless Antenna
No
Weatherproof
IP66
Heater
Yes (on: 40 ˚C, off: 30 ˚C)
Blower
Yes (on: 0 ˚C, off: 10 ˚C)
Data Transmission
+ Data Transmission Rate: 10/100 Mbps
+ Transmission Distance: <100 m
+ Ethernet Data Line: TIA/EIA-568, Cat-5 Cable
Fiziksel Özellikler
Power Input
+ 24 V AC, 50/60 Hz
+ 802.3af PoE
Power Consumption
35 W
Operating Temperature
-30 to 50 ˚C
Storage Temperature
-30 to 60 ˚C
Humidity
95% RH non-condensing
Weight
900 g
Certifications
CE (Class B), FCC (Class B)
Çözümler
Sipariş Bilgisi
DCS-71P  7" Outdoor Dome Housing
Görseller
DCS-71P
Front view
İndir
Destek Merkezi
