Hızlı Arama
Ürün Özellikleri:
"Cube" 1 megapiksel Network IP kamera
EOL EOS
Genel Özellikler:
Fiziksel Özellikler
Main characteristics:
  • ¼ inch million pixel progressive CMOS sensor
  • Minimum illumination: 1.0 lux
  • 10x digital zoom
  • Built-in lens with a fixed focal length 3:45 mm
  • Aperture F2.0
  • Reviews angles:
  •         Horizontal: 57.8 o
  •         Vertical: 37.8 o
  •         Diagonally: 66 and
Video functional:
  • Image quality, size and velocity of
  • Text and time stamps recording option
  • Outdoor motion detection to identify
  • Three personal templates
  • Setting the shutter speed, brightness, sharpness, contrast
Video Compression:
  • Image compression of the following formats: H.264/MPEG4/MJPEG
  • JPEG shots sustapdytiems
  • H.264/MPEG-4 multicast streaming
Video image resolution is able to:
  • 16:9 - 1280x800, 1280x720, 800 х 450, 640 х 360 х 480 270 320 176 х 176 х 144 at 30 frames / s
  • 4:3 - 1024 x 768, 800 x 600, 640 x 480, 480 x 360, 320 x 240, 176 x 144 at 30 frames / s
Audio support:
  • G.726
External Interfaces:
  • 1 DI / 1 DO
  • Micro SD card slot
  • Built-in microphone
  • Audio outgoing port (3.5 mm)
Network protocols:
  • IPv4, TCP / IP, UDP, ICMP, DHCP Client, NTP Client (D-Link), DNS Client, DDNS Client (D-Link), SMTP Client, FTP Client, HTTP / HTTPS, Samba Client, PPPoE, UPnP Port Forwarding RTP / RTSP / RTCP, IP filtering, 3GPP, IGMP, ONVIF
Security:
  • Administrator and user group security event log
  • Authentication password
  • Digital encryption for HTTP and RTSP
System Requirements:
  • Operating system: Windows 7/Vista/XP/2000
  • Browser: Internet Explorer, Firefox, Netscape, Opera
Event Management:
  • Motion Detection
  • Notification of events and pictures or video scanning via HTTP, SMTP or FTP
  • Multiple HTTP, SMTP and FTP servers support
  • Several reports on events
  • Several ways to create backup
Remote control:
  • Setting selection in the Web browser
  • Ability sustapdytus shots or video clips via a Web browser to save to your hard drive or network repository
PDAs, mobile phones and software support:
  • Windows 7/Vista/XP, handheld, or mobile phone with 3GPP support
System requirements when you want to use D-ViewCam:
  • Operating System: Windows 7/Vista/XP
  • Browser: Internet Explorer 6 or later
  • Protocol: TCP / IP
D-ViewCam features:
  • Management / control: up to 32 cameras
  • Ability to view 32 cameras on a single screen view
  • In support of management functions through the Web user interface
  •  Ability to capture an image sensor triggered or manually
Physical parameters
Meals:
  • Incoming: 5 V DC, 1.2 A, 50/60 Hz
Maximum power:
  • 2 W
Dimensions (mm):
Size:
  • 68 g
Working temperature:
  • 0 º to 40 º C
Storage temperature:
  • -20 º to 70 º C
Humidity:
  • 20% to 80% without condensation
Certifications:
  • The FCC Class B
  • CE
  • CE LVD
  •  C-Tick
Ürünler | Destek  | Haberler  | Hakkında |
