Hızlı Arama
Ürün Özellikleri:
Network 802.11n wireless two-megapixel IP-camera «Cube» with support for Full HD and H.264
Genel Özellikler:
Fiziksel Özellikler
Camera
Key Features
• 1/2.7-dyuymovy megapixel progressive CMOS-sensor
• Distance of IR illumination: 5 m
• Minimum illumination: 0 lux with IR LED
• Built-in ICR-filter
• Built-in PIR (Passive Infrared) sensor
• Built-in microphone and speaker
• 10x digital zoom
• Fixed focal length: 4.37 mm
• Aperture F2.0
• Viewing angle:
  - Horizontal 67.4 °
  - Vertical 40.8 °
  - Diagonal 75 °
Functional video
• Adjust the size, quality, frame rate and bit rate image
• The timings and paste text
• Windows to configure motion detection
• 3 customizable private mask
• Configurable shutter speed, brightness, saturation, contrast and sharpness
Video Compression
• Video compression formats H.264/MPEG4/MJPEG
• JPEG for still images
Video Resolution
• 16:9 - 1920x1080 (up to 15 frames per second), 1280x720, 800 x 450, 640 x 360, 480 x 270, 320 x 176, 176 x 144 at 30 frames per second
• 4:3 - 1440h1080 (up to 15 frames per second), 1280 x 960, 1024x768, 800 x 600, 640 x 480, 320 x 240, 176 x 144 at 30 frames per second
Audio Support
G.726
Device Interfaces
• Ethernet 10/100 BASE-TX (with PoE for DCS-2210)
• Wireless Interface 802.11n (only DCS-2230)
• 1 DI / 1 DO
• Slot for Micro SD-Card
Network Protocols
IPv4, TCP / IP, UDP, ICMP, DHCP Client, NTP Client (D-Link), DNS Client, DDNS Client (D-Link), SMTP Client, FTP Client, HTTP / HTTPS, Samba Client, PPPoE, UPnP Port Forwarding , RTP / RTSP / RTCP, IP filtering, 3GPP, IGMP, ONVIF
Safety
• Security administrator account and user groups
• Password authentication
System control
System requirements for the web-based interface
• Operating System: Microsoft Windows 7/Vista/XP/2000
• Browser: Internet Explorer, Firefox, Netscape, Opera
Event Management
• Motion detection
• PIR-sensor for motion detection
• Event notification and downloading snapshots / video clips via HTTP, SMPT or FTP
• Support for multiple servers, HTTP, SMPT and FTP
• Multiple event notifications
• Several ways to create backups
Remote management
• Setting up a web-browser
• Obtaining snapshots / video and save to your local hard drive or NAS via web-browser
Support for mobile phones
Windows 7/Vista/XP, Pocket PC or a mobile phone that supports 3GPP
System requirements for the D-ViewCam ™
• Browser: Internet Explorer 6 or higher
• Protocol: TCP / IP
Features available in the D-ViewCam ™
• Remote management / control of up to 32 cameras
• View images from 32 cameras on one screen
• Supports all management functions through a web-based interface
• Recording Option detected image or manually
Fiziksel Özellikler
Power Input
5 VDC 1.2 A, 50/60 Hz
Max. power consumption
4 W
Operating temperature
From 0 to 40 ° C
Storage temperature
-20 To 70 ° C
Humidity
From 20% to 80% (non-condensing)
Measurements
Weight
75 grams
Certifications
CE, CE LVD, FCC (Class B), C-Tick
Ürünler | Destek  | Haberler  | Hakkında |
