Hızlı Arama
Ürün Özellikleri:
802.11n Wireless Internet Camera with mydlink support service
Genel Özellikler:
Fiziksel Özellikler
System Requirements
• Operating System: Microsoft Windows XP, Vista, Windows 7
• Internet Explorer 6 or higher, Firefox 3.5 or higher, Safari 4
Network Protocols
• IPV4, ARP, TCP, UDP, ICMP
• DHCP-client
• NTP-client (D-Link)
• DNS-client
• DDNS-client (DynDNS, and D-Link)
• SMTP-client
• FTP-client
• HTTP-server
• PPPoE
• Port Forwarding UPnP
• LLTD
• UPnP-X1
Built-in network interface
• 10/100BASE-TX Fast Ethernet
• 802.11b/g/n WLAN
Wireless connection
• 802.11b/g/n with data encryption protocols WEP/WPA/WPA2
Transmitter output power
• 16 dbm for 11b, 12 dbm for 11g, 12 dbm for 11n (typical)
SDRAM
• 32 MB
Flash-memory
• 4 MB
Reset button
• Return to factory default settings
Support for video compression algorithms
• MJPEG
• JPEG for still photography
Video Properties
• Adjustable image size and quality
• Time stamp and text
• Rotating and Mirroring
Video Resolution
• 640 x 480 resolution and 20 frames / s
• 320 x 240 up to 30 frames / s
• 160 x 120 up to 30 frames / s
Lens
• Focus: 5.01 mm, F2.8
Sensor
• 1/5 inch VGA CMOS-sensor
Minimum illumination
• A lux@F2.8
Viewing angles
• Horizontal: 45.3 °
• Vertical: 34.5 °
• Diagonal: 54.9 °
Digital zoom
• Up to 4x
3A Control
• Automatic Gain Control (AGC)
• Automatic White Balance (AWB)
• Automatic Electronic Shutter (AES)
Power
• Input: 100-240 VAC, 50/60 Hz
• Output: 5 VDC, 1.2 A
• External switching power adapter AC / DC
Dimensions (W X D X B)
• With bracket and stand: 65.8 x 65 x 126 mm
• Only the camera: 27.2 x 60 x 96 mm
Weight
• 76.9 g (without bracket and stand)
Maximum power consumption
• 2 W
Operating temperature
• From 0 C to 40 ° C
Storage temperature
• From -20 C to 70 ° C
Humidity
• 20-80% RH non-condensing
Emission (EMI), Safety, and other certificates
• FCC Class B
• IC
• C-Tick
• CE
Ürünler | Destek  | Haberler  | Hakkında |
