DCS-930LEOL EOS
802.11n Wireless Internet Camera with mydlink support service
Nereden Alınır
Tanımlama
Surveillance Camera for home and office
DCS-930/930L - a versatile and unique solution for the small office and home. In contrast to standard Web-cameras DCS-930/930L a complete system with a built-in CPU and web-server that transmits high quality video images for security and surveillance. Simple installation and an intuitive Web-based interface offer easy integration with Ethernet / Fast Ethernet or wireless network 802.11n. DCS-930/930L also comes with remote monitoring and motion detection features for a complete and effective home security solution.
802.11n wireless connectivity
DCS-930/930L wireless interface supports 802.11n, and thus a simple integration into existing network. Wireless N technology allows you to stream high-quality video to remote sites or mobile devices. Site Survey feature also allows you to easily view and connect to nearby wireless networks. DCS-930/930L an Ethernet port for connection to traditional wired networks.
Mydlink utility for quick and easy access to the video (DCS-930L)
With the convenient mydlink ™ utility, you can quickly set up the camera DCS-930L, then register it on the web-site mydlink ™.DCS-930L will then automatically configure and connect to the service mydlink ™ for easy access to the video from anywhere on the Internet.
Easy setup and easy to use
The network camera supports Plug-n-Play, which allows computers running on Windows XP/Vista/7 to automatically recognize the camera and add it to the network. Sign up with one of the free servers DDNS, you can set the camera domain name (for example, mycamera.dlinkddns.com). This will allow the use of remote access to the camera without knowing its IP-address.Software D-ViewCam D-Link allows you to view up to 32 cameras on a single computer screen. Users can set up an automatic notification by e-mail to be instantly informed of unusual activities.
Genel Özellikler
Fiziksel Özellikler
System Requirements
• Operating System: Microsoft Windows XP, Vista, Windows 7
• Internet Explorer 6 or higher, Firefox 3.5 or higher, Safari 4
Network Protocols
• IPV4, ARP, TCP, UDP, ICMP
• DHCP-client
• NTP-client (D-Link)
• DNS-client
• DDNS-client (DynDNS, and D-Link)
• SMTP-client
• FTP-client
• HTTP-server
• PPPoE
• Port Forwarding UPnP
• LLTD
• UPnP-X1
Built-in network interface
• 10/100BASE-TX Fast Ethernet
• 802.11b/g/n WLAN
Wireless connection
• 802.11b/g/n with data encryption protocols WEP/WPA/WPA2
Transmitter output power
• 16 dbm for 11b, 12 dbm for 11g, 12 dbm for 11n (typical)
SDRAM
• 32 MB
Flash-memory
• 4 MB
Reset button
• Return to factory default settings
Support for video compression algorithms
• MJPEG
• JPEG for still photography
Video Properties
• Adjustable image size and quality
• Time stamp and text
• Rotating and Mirroring
Video Resolution
• 640 x 480 resolution and 20 frames / s
• 320 x 240 up to 30 frames / s
• 160 x 120 up to 30 frames / s
Lens
• Focus: 5.01 mm, F2.8
Sensor
• 1/5 inch VGA CMOS-sensor
Minimum illumination
• A lux@F2.8
Viewing angles
• Horizontal: 45.3 °
• Vertical: 34.5 °
• Diagonal: 54.9 °
Digital zoom
• Up to 4x
3A Control
• Automatic Gain Control (AGC)
• Automatic White Balance (AWB)
• Automatic Electronic Shutter (AES)
Power
• Input: 100-240 VAC, 50/60 Hz
• Output: 5 VDC, 1.2 A
• External switching power adapter AC / DC
Dimensions (W X D X B)
• With bracket and stand: 65.8 x 65 x 126 mm
• Only the camera: 27.2 x 60 x 96 mm
Weight
• 76.9 g (without bracket and stand)
Maximum power consumption
• 2 W
Operating temperature
• From 0 C to 40 ° C
Storage temperature
• From -20 C to 70 ° C
Humidity
• 20-80% RH non-condensing
Emission (EMI), Safety, and other certificates
• FCC Class B
• IC
• C-Tick
• CE
Çözümler
Sipariş Bilgisi
Görseller
DCS-930L/B
Left side view
View from the right
Front view
Back view
DCS-930L/A
Front view
İndir
Destek Merkezi
