DCS-6010LEOL EOS
Wireless 802.11n IP-video camera with a viewing angle of 360 ° and a support service mydlink
Nereden Alınır
Tanımlama
Wireless 802.11n IP-video camera with a viewing angle of 360 ° DCS-6010L, equipped with a lens fisheye ("fish-eye"), two-megapixel sensor and a maintenance service mydlink, is the perfect solution for video surveillance over a large area
360 ° viewing angle
DCS-6010L uses a lens fisheye, to provide an incredibly wide viewing angle. Just place the camera on the wall for a panoramic view of the room or place the camera on the ceiling for the 360-degree view of the lack of dead zones. Distortion correction function captures an image from the camera, so you can use the ePTZ to zoom, remote and turn the camera images and video surveillance of a large area.
Remote access through the service mydlink
Wireless 802.11n IP-video camera with a viewing angle of 360 ° DCS-6010L supports service mydlink, allowing you to access and configure the camera remotely, regardless of location. You can view the camera image in real time over the Web-site mydlink, or you can download the mobile app mydlink and monitor directly to your mobile device with iOS or Android. Watch out for the house when you're at work or supervise work in the office when you're on the road, with the help of service mydlink.
Zero Configuration Mechanism
If you have a router that supports the service mydlink, then through the mechanism of Zero Configuration to install and configure DCS-6010L is not difficult. Simply connect the camera to the power adapter, and then - to the mydlink router using Ethernet-cable. The camera will be automatically added to your account. Mydlink service allows even inexperienced users to easily install and use cameras that support this service.
Ready, scalable solution for video surveillance
DCS-6010L is a standalone solution for video surveillance lets you record still images and video on a Micro SD card and does not require a PC or network storage device.
Options to expand video surveillance kit includes software D-ViewCam, providing the opportunity to control up to 32 cameras with a wide range of functions, including viewing of multiple cameras and automatic e-mail alert to suspicious or unusual activity.
Versatility
DCS-6010L has a host of features that enhance the surveillance capabilities and make the camera ideal for any situation. Built-in microphone and speaker provide two-way audio transmission performance of the signal or siren when a specific event. DCS-6010L also supports wireless 802.11n, allowing you to place the camera anywhere without the need to lay Ethernet-cable.
Genel Özellikler
Fiziksel Özellikler
Camera
Hardware profile camera
• 1/3 inch, 2-megapixel CMOS-sensor with progressive scan
• Minimum illumination: 2 lux
• Built-in microphone and speaker
• 10x digital zoom
• Focal length: 1.25 mm
• Aperture: F2.0
• Viewing angle:
  - 180 (horizontal)
  - 180 (vertical)
  - 180 (Diagonal)
Image characteristics
• Setting the image size and quality, frame rate and bit rate
• fisheye distortion correction
• The timings and paste text
• Adjust brightness, color saturation, contrast and sharpness
• Customizable windows for motion detection
Video Compression
• Compression formats H.264/MPEG-4/MJPEG
• H.264/MPEG-4 multicast streaming
• JPEG for still images
Video Resolution
1600 x 1200, 1200 x 900, 800 x 600, 400 x 300 and 15 frames / s 1
Audio Support
• G.726
• G.711
Interfaces to external devices
• Port 10/100 BASE-TX Fast Ethernet
• Wireless 802.11n
• Card slot Micro SD / SDHC
Network
Network Protocols
• IPv6
• IPv4
• TCP / IP
• UDP
• ICMP
• DHCP-Client
• NTP-Client (D-Link)
• DNS-client
• DDNS-Client (D-Link)
• SMTP-client
• FTP-client
• HTTP / HTTPS
• Samba-client
• PPPoE
• UPnP port forwarding
• RTP / RTSP / RTCP
• Filtering IP-addresses
• QoS
• CoS
• Multicast
• IGMP
• ONVIF
Safety
• Security administrator account and user groups
• Password authentication
• Encryption HTTP and RTSP
System control
System requirements for Web-based interface
Web-browser: Internet Explorer, Firefox or Chrome
Event Management
• Motion detection
• Event notification and download stop-kadrov/videoklipov via email or FTP
• Support for multiple SMTP servers, and FTP
• Multiple event notifications
• Several ways to create backups
Remote management
• Create stop-kadrov/videoklipov and save to a local hard drive or NAS via Web-browser
• Interface settings, available through the Web-browser
Support for mobile devices
• OS Windows 7/Vista/XP, PDA or mobile phone
• Mobile mydlink app for mobile devices running iOS and Android
System Requirements D-ViewCam ™
• Operating System: Microsoft Windows 7/Vista/XP
• Web-browser: Internet Explorer 7 or above
• Protocol: Standard TCP / IP
The software features D-ViewCam ™
• Remote management / control of up to 32 cameras
• Viewing images on a single screen: up to 32 cameras
• Supports all management functions in the Web-interface
• Recording Options for triggering a sensor or manually
Fiziksel Özellikler
Weight
267 g ± 5%
No external power adapter
• Input: 100-240 VAC, 50/60 Hz
• Output: 5 VDC, 1.2 A
Power consumption
3.9 W (maximum)
Temperature
• Operating: 0 to 40 C
• Storage: -20 to 70 C
Humidity
• Operating: 20% to 80% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certifications
• CE
• CE LVD
• FCC
• C-Tick
Measurements
1 Frame rate when transmitting video in real time may vary depending on the network conditions and the method used.
Çözümler
Sipariş Bilgisi
Görseller
DCS-6010L
Left side view
Back view
Front view
İndir
Destek Merkezi
