DCS-3010
HD-Video Camera with PoE
Nereden Alınır
Tanımlama
HD-Camera D-Link DCS-3010 is equipped with PoE megapixel 1/4-inch CMOS-sensor with progressive scan and a lens with a focal length of 4 mm. The camera enables you to capture HD-video with a resolution up to 1280x800 at up to 30 frames per second. You can save snapshots and videos on a network drive or on SD-card connected to the camera.
High-resolution video monitoring
Built-megapixel sensor produces snapshots and video quality with resolution up to 720p, providing high-definition video capture with all the details. Functions ePTZ provide zoom in / out the video, and pan across the image received from the camera. Thus, it is easy to monitor a large area. Support for Power over Ethernet (PoE) allows you to install the camera in locations where power outlets are not available.
Support for multiple video streams
To increase bandwidth efficiency and increase the image quality camera DCS-3010 uses the simultaneous streaming of video formats MJPEG, MPEG-4 and H.264. In addition, the camera can organize multicast data streams and provide access to video on demand.
Complete solution for conducting surveillance
Camera DCS-3010 is a complete solution for surveillance, providing snapshots and record video to MicroSD-card, eliminating the need to use a computer or network storage device. To enhance the video surveillance package includes free software D-ViewCam, designed to control the 32 cameras with a wide range of functions, such as viewing the images from multiple cameras at the same time and send to e-mail notifications of suspicious events or emergency situations.
Genel Özellikler
Fiziksel Özellikler
Hardware profile camera
• megapixel 1/4-inch CMOS-sensor
• 256 MB of SDRAM
• 32 MB of flash memory
• Removable lens with a focal length of 4 mm
• Aperture: F1.5
• Viewing angle:
  - 56.9 (H)
  - 35.9 (vertical)
Image characteristics
• Setting the image size and quality, frame rate and bit rate
• The timings and paste text
• 3 configurable motion detection windows
• 5 customizable zones of private masks
• Adjust brightness, color saturation, contrast and sharpness
Video Compression
• Compression formats H.264/MPEG-4/MJPEG
• Multicast streaming video formats H.264/MPEG-4
• JPEG for still images
Video Resolution
• 16:9 - 1280 x 800, 1280 x 720, 800 x 450, 640 x 360, 480 x 270, 320 x 176, 176 x 144 and 30 frames / s 1
• 4:3 - 1024 x 768, 800 x 600, 640 x 480, 480 x 360, 320 x 240, 176 x 144 and 30 frames / s 1
Audio Support
• Speech Coding GSM-AMR, rate: 4.75 kbit / s to 12.2 kbit / s
• Audio Coding G.711, bit rate: 8 kbit / s to 64 kbit / s
• Audio Encoding MPEG-4 AAC, transfer rate: 16 kbit / s to 128 kbit / s
Interfaces to external devices
• Port 10/100 BASE-TX Fast Ethernet
• Supports 802.3af PoE
• Card slot Micro SD / SDHC
• External audio-vhod/vyhod
Network Protocols
• IPv4
• TCP / IP
• UDP
• ICMP
• DHCP-Client
• NTP-Client (D-Link)
• DNS-client
• DDNS-Client (D-Link)
• SMTP-client
• FTP-client
• HTTP / HTTPS
• Samba-client
• PPPoE
• UPnP port forwarding
• RTP / RTSP / RTCP
• Filtering IP-addresses
• QoS
• CoS
• Multicast
• IGMP
• ONVIF
Safety
• Security administrator account and user groups
• Password authentication
• Streaming HTTPS
• Encryption HTTP and RTSP
• Control of remote client access
System requirements for Web-based interface
Web-browser: Internet Explorer, Firefox, Chrome
Event Management
• Motion detection
• Event notification and download stop-kadrov/videoklipov via email or FTP
• Support for multiple SMTP servers, and FTP
• Multiple event notifications
• Several ways to create backups
Remote management
• Create stop-kadrov/videoklipov and save to a local hard drive or NAS via Web-browser
• Interface settings, available through the Web-browser
System Requirements D-ViewCam ™
• Operating System: Microsoft Windows 7/Vista/XP
• Web-browser: Internet Explorer 7 or above
• Protocol: Standard TCP / IP
The software features D-ViewCam ™
• Remote management / control of up to 32 cameras
• Viewing images on a single screen: up to 32 cameras
• Recording Options for triggering a sensor or manually
• Supports all management functions available through the Web-based interface
Fiziksel Özellikler
Weight
165 g
Nutrition
• 12 VDC, 0.5 A
• 802.3af PoE
Power consumption
4.6 W (12 V DC), 6.6 W (PoE)
Temperature
• Operating: 0 to 40 C
• Storage: -20 to 70 C
Humidity
• Operating: 20% to 80% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certifications
• CE
• CE LVD
• FCC
• C-Tick
Measurements
Çözümler
Sipariş Bilgisi
Görseller
DCS-3010
View from the right
Back view
Left side view
View from the right
Left side view
İndir
Destek Merkezi
