DCS-5020LEOL EOS
Wireless 802.11n IP-camera with tilt and rotate the drive, the possibility of night shooting and support service mydlink
Tanımlama
Network Camera DCS-5020L supports a wide range of functions for the effective day and night surveillance in a home or small office. Pan and tilt mechanism provides coverage of a large area surveillance and integrated infrared illumination allows for round the clock surveillance regardless of the lighting conditions. Wireless connectivity allows you to connect to an existing wireless network without the need for network cables, if necessary, extend the range of the network.
Round the clock surveillance
DCS-5020L is a stand-alone camera that does not require any special hardware or software and can work on their own, even without a computer. Using the Camera DCS-5020L and Internet connection lets you send a notification to snapshots or video clips via e-mail when motion or sound. You can set up motion detection area, for example, the entrance to the building, and you can set a threshold sound level above which the camera will be fixed, for example, to hear a baby crying or the noise generated by an attacker. Built-in infrared illumination allows to conduct surveillance at night at a distance of 8 meters.
Constant remote access to video using a cloud service mydlink
Support Camera DCS-5020L mydlink ™ service makes monitoring your home or office easier, more convenient and allows you to stay connected regardless of their location. To view the video from the camera can use the Web-site mydlink, as well as additional applications mydlink mobile devices with iOS or Android. Mydlink app allows the user using Wi-Fi, 3G or 4G connection to quickly and easily view the video from the camera.
Clear images at different angles
Thanks to the pan / tilt and digital zoom IP-Camera DCS-5020L provides an overview of a large area from different angles and 4x digital zoom for detailed image. You can also configure the automatic movement of IP-cameras DCS-5020L between preset positions, allowing you to patrol a large area.
Large range of a wireless network with 802.11n standard
The wireless connection 802.11n camera DCS-5020L can be placed anywhere in the home or small office. You can also use the repeater mode to extend the range of an existing wireless network.
Multifunctional surveillance system
The included DCS-5020L software D-ViewCam allows you to extend the functionality of the camera to create a complete video surveillance system. With the D-ViewCam can centrally manage multiple network cameras (up to 32 cameras and up to 64 users), to record a wide range of functions, including recording triggered sensors on a schedule or manually.
