DCS-210EOL EOS
Software D-ViewCam Standard
Tanımlama
Multifunctional software DCS-210 D-ViewCam Standard is an integrated surveillance system for corporate users. This software provides the ability to centrally manage and view up to 8 cameras and compatible with the current IP-cameras and video servers D-Link. DCS-210 provides the monitoring and recording of video, audio and events used in various applications to ensure security. Moreover, the software provides users with a wide range of features video recording and playback, and view real-time.
Monitoring in real time and centralized management
Multifunctional software DCS-210 provides centralized control of up to 8 cameras and displays in real time. Appendix "E-Card" allows you to create maps based on the location and position of the camera. All connected cameras are displayed for easy viewing in the tree of devices. Additional features, such as patrol, rotate, zoom and focus, provide optimal control in the conduct of surveillance.
Video recording and playback
D-ViewCam Standard supports scheduled recording, motion detection recording, or manually, depending on your requirements.Search for recorded files is performed according to their type or select a playback interface. Recorded videos can be edited or exported to AVI / ASF format.
Notification settings
Software DCS-210 provides enhanced monitoring and protection through notification of events detected thanks to smoke detectors, door sensor, alarm button, camera, card reader or other device I / O. Connect any of these devices to the I / O enabled camera D-Link, and when an event occurs D-ViewCam Standard will be notified immediately and will inform the user by e-mail or via an audible alarm.
Backing up the database
Software D-ViewCam Standard supports playback function that allows you to download and play the recorded file on a computer running Windows. In this case, users are able to monitor in real time on a single computer and view recorded video on the other. Software D-ViewCam Standard also provides users with database maintenance utility (DBTool), which can be used to restore the database or change the place of its location on a local or external drive. The software also supports the import / export of configuration files, allowing users to sync settings for a variety of surveillance devices.
Compatibility with third-party CMS (Central Management System)
CMS (Central Management System) provides the ability to manage network cameras, in any quantity, providing simultaneous operation of an unlimited number of workstations. The CMS is a feature-rich solution for large-scale projects, its use in the municipal surveillance system helps to prevent illegal acts and protects government organizations and businesses operating on an international level. It is compatible with the CMS software D-ViewCam Standard provides comprehensive protection.
