Hızlı Arama
Ürün Özellikleri:
D-ViewCam Software
Genel Özellikler:
Fiziksel Özellikler
Support for cameras
• Support for up to 32 cameras
• Support of megapixel network cameras
Video Compression
Compression formats MJPEG/MPEG-4/H.264
The software features
• Setting the OSD (On-screen Display)
• Monitoring in real time
• Record up to 30 frames / second for each camera (depending on the camera model and the free space on a video server)
• Automatic detection of network cameras
• Support for multiple languages
• Changing the configuration during operation
• E-mail Alerts
• The locking system to prevent unauthorized access
Account Management System
• User Authentication
• Limit to change the password for the user
• Creating a User Profile
• Control access based on privileges
Record
• Support for multiple locations to store records
• Scheduled Recording
• Event Recording
• Protection of the recorded data
• Supports Pre / post-recording
• Support for manual recording
• Single record sound from multiple channels
• Record and view in real time with different frame rates and different resolutions
Search and playback
• Control playback video
• The method of fast video search using the histogram
• date / time stamp for video
• Get snapshots from video
• Convert video formats to AVI / ASF
• Support for remote playback / playback through Web-browser
Video Mode
• Split screen
• Support drag and drop the video on the screen
• Support for video in full screen mode
• Information Window
• Enable the PTZ camera control with support for PTZ
• Supports digital zoom in / out
• Duplication of the camera
• Supports remote live viewing
Map mode
• Support for multiple cards
• Notification of alarm
• The background map, a user-configurable
• Preview Image
• Display the status of the camera and sensor I / O
PTZ Control
• Auto Pan
• Manual control
• Points Patrol (depending on the device)
• Patrolling at predetermined points
• Supports multiple patrols
Function input-output
• Control output port
• Operation of the port of entry by event
• Send a signal to the output port at an event
Backup
• Create a backup of the database for magazines and videos
• Import / Export Configuration File
• Utility Database Maintenance - DB tool
• Writing backups to DVD in Windows XP
Fiziksel Özellikler
Minimum system requirements 1
• CPU: Intel Core 2 Duo E5300
• RAM: 2 GB
• Parent Card: Asus Gigabyte board recommended on the chipset Intel P55, H55, X58, P45, P43 or MSI on Intel
• Video card: ATI Radeon 4650 or higher (Driver ATI V11-2)
• Ethernet: 100Base-T or above, Gigabit LAN recommended
• Hard Drive 2 : 250 GB or above
• Operating system:
   32-bit: MS Windows XP pro SP3/Vista SP1/Win SP1/Win 7 8
   64-bit: Win 7 SP1/Win Server 2008 R2/Win 8, Win Server 2012
1 To determine the minimum hardware requirements for equipment proposed video surveillance system, if they are not listed in the above table, please consult with a system integrator, supplier, or contact technical support for D-Link.
2 Video Recording for a longer period of time will require a large amount of free disk space. Before using the recording, please make sure you have sufficient disk space.
Ürünler | Destek  | Haberler  | Hakkında |
