DCS-250Yeni
D-ViewCam Plus
Nereden Alınır
Tanımlama
The DCS-250 D-ViewCam Plus is a comprehensive network camera surveillance software designed for enterprise users. It centrally manages 32 network cameras and is compatible with current D-Link network cameras, video servers and a large range of third party network cameras 1. This software offers digital monitoring and recording of video, audio, and events for use in various security applications. Furthermore, this easy-to-use surveillance software provides users with a wide array of features, including video recording, playback, and live view.
Live Monitoring & Centralized Management
The DCS-250 is a comprehensive surveillance system designed to centrally manage up to 32 network cameras, while displaying real-time status information. Map Mode allows you to create maps based on camera location and orientation, and the Device Tree lists all the cameras connected to the interface for easy viewing. Additional features such as patrol, rotate, zoom, and focus provide users with optimal control over their video surveillance.
Video Recording & Playback
The D-ViewCam Plus offers scheduled, motion, and manual recording options to meet specific user demands. Recorded files can be searched according to video type or selected within the user interface for playback, editing, or AVI /ASF file conversion.
Event Action Configuration
Event Action provides enhanced surveillance and security by detecting events from smoke detectors, magnetic door sensors, emergency buttons, cameras, card readers, or other I/O devices. Connect any of these devices to the I/O connector of a compatible D-Link network camera so that, when an event triggers a device, a notification is immediately sent to the D-ViewCam Plus software. The D-ViewCam Plus then notifies you either by e-mail or an audio alert.
Video & System Database Backup
The D-ViewCam Plus playback function allows users to load and play a recorded file on a Windows PC. It allows users to monitor a live feed on one computer while watching a recorded file on another. D-ViewCam Plus also provides a utility (DBTool) to reconstruct, repair, or relocate the databases in a local drive or external drive. It also supports the import/export of configuration files, enabling users to synchronize surveillance settings across devices.
Compatible with 3rd Party CMS
A Central Management System (CMS) can manage an unlimited number of network cameras worldwide, allowing simultaneous operation by unlimited workstations. A CMS is considered to be the omni-solution for large-scale projects, such as defense installations, justice facilities, security companies, city surveillance, and national and international enterprises. To meet these needs, the D-ViewCam Plus can be integrated with
Genel Özellikler
Fiziksel Özellikler
Cameras
• Supports up to 32 cameras
• Support of megapixel network cameras
Video compression formats
MJPEG/MPEG-4/H.264
The software features
• Working with two monitors
• Full Screen
• Setting the OSD (On-screen Display)
• Monitoring in real time
• Record up to 30 frames per second
• Automatic detection of network cameras
• Support for multiple languages
• Changing the settings in real time
• The auto restart
• Support DDNS
• SMS-notification
• The locking system to prevent unauthorized users
Account Management
• User Authentication
• Limit to change the password for the user
• Creating a User Profile
• Access rights
Record
• Specify multiple locations to store records
• Scheduled Recording
• Record when an event occurs
• Protection of the recorded data
• Pre-record (Pre-record) and Post-recording (Post-record)
• Manual Recording
• One-way audio recording from multiple channels
• Display and recording in real time at different frame rates and resolution
Search and playback
• Control playback
• Intelligent Search (Smart Search)
• The histogram method to quickly search videos
• date / time stamp for video
• Get snapshots from video
• Convert video formats to AVI / ASF
• Remote Playback / Playback via Web-browser
Video Mode
• Split screen
• The ability to move the image on the screen using the «drag-and-drop» (drag and drop)
• View the video in full screen mode
• Information Window
• View multiple video streams
• Enable the PTZ to control the pan / tilt / zoom (PTZ)
• Digital zoom in and out
• Duplication of the camera
• The remote viewing in real time
E-map
• Support for multiple cards
• Notification of Emergency
• The background maps, user-selectable
• Preview Image
• Display the status of the camera and sensor I / O
PTZ function
• Auto Pan
• Manual control
• Points Patrol (depending on the device)
• Patrolling at predetermined points
• Supports multiple patrols
I / O
• Digital output control
• Digital Output
• Turning the camera to a preset position when the signal to the digital input from external sensors
• Sending an SMS when a signal to the digital input
• Sending messages CMS when the signal to the digital input
• E-mail Alerts
Backup
• Backup the database logs and videos
• Import / Export Configuration File
• Record the backup files to a DVD, if your computer is running Windows XP
• Automatic backup
Compatibility
• ONVIF
• Support Device Pack
• Compatible with D-Link NVR
• Compatible with the sides of the central control system (CMS)
• Support Adapter D-Link DWM-152-A3/156-A3/156-A6 3,5 G / 3,75 G
• Compatibility with network cameras, D-Link (for more information on the compatibility list, please visit www.dlink.ru)
Tools
• The program for remote viewing in real time (Remote Live Viewer)
• Playback system
• Backup System
• A utility for database maintenance DB Tool
• Utility Verification Tool (check tool)
• Remote Desktop
Fiziksel Özellikler
Minimum system requirements
• CPU: Intel Core 2 Duo E5300
• RAM: 2 GB
• Motherboard: On the chipset Intel P55, H55, X58, P45, P43 manufacturers ASUS, Gigabyte or MSI on Intel
• Video card: ATI Radeon 4650 or better (ATI Driver V11-2)
• Ethernet: 100Base-T or above, Gigabit LAN recommended
• Hard Drive 2 : 250 GB or more
• OS
  32-bit: MS Windows XP pro SP3 / Vista SP1 / Win 7 SP1
  64-bit: Win 7 SP1 / Win Server 2008 R2
1 In order to determine the minimum system requirements for video surveillance equipment for the job (if they are not specified in the list), please consult with a system integrator, supplier, or contact technical support for D-Link.
2 video file recorded over a long period of time may take up a lot of disk space. Before using the recording, please make sure you have sufficient disk space.
Çözümler
Sipariş Bilgisi
Görseller
İndir
Destek Merkezi
