DCS-4602EV/UPAEOL
Full HD Outdoor Vandal Proof PoE Dome Camera
Nereden Alınır
Tanımlama
The Vigilance Full HD Outdoor Vandal-Proof PoE Dome Camera is a professional, full featured HD camera is easy to install and highly affordable. Designed for use in harsh environments, it has a toughened metal body, industry-certified IK10 (vandal-proof) dome and IP66 (weather-proof) housing. Incorporating IR LED illuminator, WDR and 3DNR support, you get up to 20 metres night vision and clear detailed images in contrasting and low light environments.
Vigilance range
The Vigilance Range offers professional, full featured high definition video surveillance that is easy to install and highly affordable. The range consists of cameras designed specifically to meet different surveillance and environmental requirements. From standalone surveillance solutions that allow you to record video without additional software or equipment, to weather/vandal-proof cameras for harsh environments.
Security Installer Focused
Specifically designed for any security installer looking to offer digital video surveillance, this versatile range of cameras is designed for easy selection and simple installation. You'll be able to guide your customers to the right choice for their needs and they will be delighted with the quality, reliability and straightforward ease-of-use that Vigilance delivers.
Genel Özellikler
Fiziksel Özellikler
Functions & Features
Features
  • Full HD 1080p, 30 fps
  • Day and night with ICR filter and IR LED
  • 20m night vision
  • Wide Dynamic Range
  • 3D Noise Reduction
  • Supports Power over Ethernet
  • IP66 outdoor certified
  • IK-10 vandal-resistance rating
Technical Specifications
Hardware Features
Indoor/Outdoor
  • Indoor and outdoor IP66
Vandal-Proof
  • Yes (IK10)
Image Sensor
  • 1/3” 2-Megapixel progressive scan CMOS
Maximum Video Resolution (Ratio)
  • 1920 x 1080 (16:9)
  • 1400 x 1080 (other)
Maximum Frame Rate
  • Up to 30 fps
Lens
  • Fixed 2.8 mm, F1.8
Minimum Illumination (Lux)
  • 1.0 lux/F2.0  (colour)
  • 0.5 lux/F2.0  (B/W)
  • 0 Lux (B&W, IR-LED on)
Infrared-Cut Removable Filter
  • Yes
IR Built-in
  • 20 m
Wide Dynamic Range (WDR)
  • Yes
3D Noise Reduction
  • Yes
Angle Of View (H/V/D)
  • 96° / 54° / 108°
Gimbal
  • 2-Axis
  • Vertical: 60° / Horizontal 350°
Privacy Masks
  • 3 zones
Wired Connection
  • Fast Ethernet (10BASE-T, 100BASE-TX)
  • Power over Ethernet (802.3af PoE)
Software Features
Video Format
  • H.264
  • MJPEG
Multi-Stream
  • Yes
ONVIF
  • Yes
Digital Zoom
  • 10x
Motion Detection
  • Yes
Event Recording
  • Yes
E-Mail Notification
  • Yes
Recording to NAS
  • Yes
IPv6 Support
  • Yes
Others
Dimensions
  • Φ110 × 78mm
Operating Temperature
  • -30 ~ 50°C
Operating Humidity
  • 20 ~ 80% RH (non-condensing)
Optional Power Input
  • DC power adapter (Input: 100-240VAC, 50/60Hz; Output: 12VDC, 1.5A)
Safety
  • CE (Class A)
  • CE LVD
  • FCC (Class A)
  • C-Tick
Çözümler
Sipariş Bilgisi
Görseller
DCS-4602EV/UPA
Front view
Back view
İndir
Destek Merkezi
