DCS-4201EOL EOS
Vigilance HD Wireless Camera
Tanımlama
The DCS-4201 Vigilance HD Wireless Camera is a versatile surveillance solution that is perfect for monitoring in your home or small office. It combines a high-resolution megapixel sensor with a built-in IR LED to help you keep watch over areas in complete darkness. The DCS-4201 also includes a built-in IR cut filter, making it suitable for both day and night applications. Additionally, the DCS-4201 is a complete system with a built-in CPU and web server that transmits high-quality video images for security and surveillance. The DCS-4201 features 802.11n wireless, allowing the camera to be placed anywhere within range of your wireless network.
A Complete, Expandable Surveillance Solution
The DCS-4201 is a self-sufficient surveillance solution, capable of recording snapshots and video to a microSD card without requiring a PC or network storage device. If you want to expand your surveillance options, D-ViewCam management software is also included, giving you the ability to manage up to 32 cameras with a robust set of features, including multi-camera views and automated e-mail alerts to keep you informed of suspicious or unusual activities.
Built for Versatility
The DCS-4201 comes with a wealth of features that enhance its surveillance capabilities, making it ideal for any situation. A passive infrared (PIR) sensor detects motion near the camera, allowing it to automatically record video and send you a notification when motion is detected. A built-in microphone and speaker allow for 2-way communication, which is ideal for use in entryways or for caretaker applications.
ePTZ For Surveying Regions Of Interest
The ePTZ feature allows users to select a target region for close-up viewing simply by clicking on the video feed displayed within their browser. ePTZ makes use of the camera’s  megapixel  resolution to survey a large area effortlessly. Since ePTZ requires no moving parts, there is no need to worry about the camera having mechanical failures.
Wireless N Connectivity
The Vigilance HD Wireless Camera includes 802.11n wireless for fast and easy integration into your existing network environment. Wireless N allows you to stream high quality video to remote sites and mobile devices. The DCS-4201 also includes a standard Ethernet port for connections to traditional wired networks.
Genel Özellikler
Camera
Camera Hardware Profile
• 1/4”megapixel progressive CMOS sensor
• 10 meter IR illumination distance
• Minimum illumination:
   1.0 lux (color)
   0.5 lux (B/W)
   0 Lux (IR-LED on)
• Built-in Infrared-Cut Removable (ICR) filter module
• Built-in PIR (Passive Infrared) sensor
• Built-in microphone and speaker
• 10x digital zoom
• Fixed length: 1.8 mm
• Aperture: F2.4
• Angle of view:
   (H) 97.6°
   (V) 69.2°
   (D) 108.9°
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• 3D noise filter for low light environments
• Configurable privacy mask zones
• Configurable shutter speed, brightness, saturation, contrast, and sharpness
• Wide Dynamic Range image enhancement
Video Compression
• Simultaneous H.264/MJPEG format compression
• H.264/MJPEG multicast streaming
• JPEG for still images
Video Resolution
• 16:9 - 1280 x 720, 800 x 448, 640 x 360, 480 x 272, 320 x 176 up to 30 fps
• 4:3 - 960 x 720, 800 x 592, 640 x 480, 480 x 352, 320 x 240 up to 30 fps
Connectivity
• 802.11n/g/b wireless with WEP/WPA/WPA2 encryption
• Operates on 2.4 GHz band
• Maximum data rate of 54 Mbps (PHY rate)
Audio Support
• G.711
• AAC
Device Interfaces
• 10/100 BASE-TX
• 802.11n/g/b WPS Button
• 1 DI / 1 DO
• microSD card slot
Network
Network Protocols
• IIPv6
• IPv4
• TCP/IP
• UDP
• ICMP
• DHCP client
• NTP client(D-Link)
• DNS client
• DDNS client (D-Link)
• SMTP client
• FTP client
• HTTP / HTTPS
• Samba Client
• PPPoE
• UPnP port forwarding
RTP / RTSP/ RTCP
• IP filtering
• QoS
• CoS
• Multicast
• SNMP
• ONVIF compliant
Security
• Administrator and user group protection
• Password authentication
• HTTP and RTSP authentication
System Management
System Requirements for Web Interface
• Operating System: Microsoft Windows 8/7/Vista
• Browser: Internet Explorer, Firefox, or Safari
Event Management
• Motion detection
• Event notification and uploading of snapshots/video clips via e-mail or FTP
• Supports multiple HTTP, SMTP, and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Configuration accessible via web browser
• Take snapshots/video clips and save to local hard drive
D-ViewCam™ System Requirements
• Web Browser: Internet Explorer 7 or higher
• Protocol: Standard TCP/IP
D-ViewCam™ Software Functions
• Remote management/control of up to 32 cameras
• Supports all management functions provided in web interface
• Viewing of up to 32 cameras on one screen
• Scheduled motion triggered, or manual recording options
Weight
• 445 g (15.7 ounces) ± 5%
External Power Adapter
• Input: 100 to 240 V AC, 50/60 Hz
• Output: 5 V DC 1.2 A
Power Consumption
• 4.0 ± 5% watts
Temperature
• Operating: -30 to 50 ˚C (-22 to 122 ˚F)
• Storage: -20 to 70 °C (-4 to 158 °F)
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• FCC
• C-Tick
Çözümler
Sipariş Bilgisi
Görseller
DCS-4201/Ax
Left side view
Back view
View from the right
Front view
İndir
Destek Merkezi
