DCS-2310L/UPAEOL EOS
External Cloud Network HD-camera with PoE and Night Vision
Tanımlama
External cloud network camera HD-DCS-2310L / UPA with PoE and night shooting provides round the clock outdoor surveillance.
Hour HD-CCTV
The camera is equipped with a megapixel sensor and allows you to create a clear and detailed images in HD-quality resolution up to 720p. DCS-2310L / UPA supports ePTZ detail of objects for shooting at any point of the camera.
Built-in ICR-filter during the day does not pass infra-red radiation, which contributes to a high quality image. At night, the ICR-filter is moved to the side to use a wide range of radiation surveillance in low light conditions, and together with infrared illumination allows you to monitor in complete darkness.
Outdoor video surveillance
DCS-2310L / UPA is designed to provide outdoor surveillance and made weatherproof housing with a degree of protection against dust and moisture to IP-65. Supports PoE technology allows simultaneous transmission of data and power over a single cable, which greatly simplifies installation and allows you to use the camera in places where power sources are unavailable.
Remote access via the service mydlink
Network Camera DCS-2310L / UPA supports cloud service mydlink, allowing you to access and configure the camera remotely over the Internet, regardless of location. You can view the image from the camera in real time through the Web-site mydlink, or you can download the mobile application mydlink Lite and monitor directly on your mobile device with iOS and Android. Watch out for home, when you are at work or supervise work in the office when you're on the go, using the service mydlink.
Mechanism Zero Configuration
If you have a router that supports mydlink cloud service to configure the network camera does not pose any difficulty thanks to the automatic adjustment Zero Configuration. To do this, simply connect the AC adapter to the camera, and the camera - to the router via Ethernet-cable, and the device is automatically added to the user's account. Mydlink service allows even the most inexperienced user to quickly and easily configure the camera that supports cloud service.
Universal use
DCS-2310L / UPA supports many features that extend the capabilities of CCTV camera and makes an ideal solution for any situation. PIR-motion sensor detects movement near the camera, allowing you to automatically record video and send with the notice.
The complete solution for video surveillance
Camera DCS-2310L / UPA is a standalone solution for video, allows you to record still images and video on the microSD-card and does not require a computer or network storage device.
To expand the options, CCTV supplied software included D-ViewCam, providing the ability to manage 32 cameras with a wide range of functions, including viewing of multiple cameras and automatic e-mail alert for suspicious or unusual activity.
Contents of delivery
Network Camera DCS-2310L / UPA with Stand Ethernet-Cable CD Quick installation guide and warranty card Mounting Kit Power adapter not included
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DCS-2310L/UPAB
Left side view
Back view
View from the right
Front view
İndir
Destek Merkezi
