DCS-37-3EOL
Nereden Alınır
Tanımlama
Ceiling mount angle bracket for DCS-4602EV, DCS-4603, DCS-4802E cameras. Allows you to adjust the camera vertical field-of-view by 27 degrees.
Genel Özellikler
Accessory Type
• Mounting Brackets
Dimensions (Size)
• 29 x 72,1 mm
Weight
• 73 g
Maximum load
• 4kg
Material
• Polycarbonate
Fiziksel Özellikler
Çözümler
Sipariş Bilgisi
DCS-37-3   Ceiling Mount Angle Bracket for DCS‑4602EV/4603/4802E
Görseller
DCS-37-3Ax
Back view
Front view
View from the right
İndir
Destek Merkezi
