Hızlı Arama
Ürün Özellikleri:
WIRELESS INTERNET CAMERA
EOL
Genel Özellikler:
OS SUPPORT
Device
+ Windows 2000 / Windows XP / Windows Vista / Linux/ MAC OS X10.3 or above
Utility
NETWORKING PROTOCOL
+ IPV4, ARP, TCP, UDP, ICMP
+ DHCP Client
+ NTP Client
+ DNS Client
+ DDNS Client
+ SMTP Client
+ FTP Client
+ HTTP Server
+ PPPoE
BUILT-IN NETWORK INTERFACE
+ 10/100BASE-TX Fast Ethernet
+ 802.11b/g WLAN
WIRELESS CONNECTIVITY
802.11b/g Wireless with WEP/WPA/WPA2 security
WIRELESS TRANSMIT OUTPUT POWER
16dbm for 11b, 12dbm for 11g (typical)
WIRELESS RECEIVER SENSITIVITY
(11g Packet Error Rate < 10%)
+ 54Mbps: <-66dbm
(11b Packet Error Rate <8%)
+ 11Mbps: < -82dbm
VIDEO CODEC
MJPEG
SENSOR
VGA ¼ inch CMOS Sensor
SDRAM
8 Mbytes
FLASH MEMORY
2 Mbytes
RESET BUTTON
Reset to factory default
VIDEO ALGORITHM SUPPORTED
+ MJPEG
+ JPEG for still image
VIDEO FEATURES
+ Adjustable image size and quality
+ Time stamp and text overlay
+ Flip and Mirror
RESOLUTION
+ 640 x 480 at up to 15fps
+ 320 x 240 at up to 30fps
+ 160 x 120 at up to 30fps
LUX
1 lux@F2.8
3A CONTROL
+ AGC (Auto Gain Control)
+ AWB (Auto White Balance)
+ AES (Auto Electronic Shutter)
Fiziksel Özellikler
Power
+ Input: 100-240VAC, 50/60Hz
+ Output: 5VDC, 2.5A
+ External AC-to-DC Switching Power Adapter
DIMENSION (WxDxH)
71.9mm x 110.0mm x 37mm (without bracket and stand)
WEIGHT
251g (without bracket and stand)
MAX POWER CONSUMPTION
4.25W
OPERATION TEMPERATURE
0˚ to 40˚C (32˚ to 104˚F)
STORAGE TEMPERATURE
- 20˚ to 70˚C (-4˚ to 158˚F)
HUMIDITY
20-80% RH non-condensing
EMISSION (EMI), SAFETY & OTHER CERTIFICATIONS
+ FCC Class B
+ IC
+ C-Tick
+ CE
Ürünler | Destek  | Haberler  | Hakkında |
