Hızlı Arama
Ürün Özellikleri:
Pocket Hub with 4 USB 2.0 ports
D-Link’s DUB-1040 4 Port USB 2.0 Pocket Hub provides additional USB 2.0 ports for your notebook computer, allowing you to connect additional USB devices such as digital cameras, hard drives, mice, keyboards, printers, scanners, and many other peripherals.
Add 4 USB 2.0 Ports To Your Computer
With the DUB-1040 4 Port Universal Serial Bus (USB) 2.0 Pocket Hub, easily add USB ports to your computer. Now you can connect up to 4 more USB peripherals such as your digital camera, printer, CD drive, mouse, and flash drive to your notebook computer.
Seamless Connection
The DUB-1040 4 Port USB 2.0 Pocket Hub is designed to provide quick and easy access to the 4 USB 2.0 ports. A USB cable is provided to connect to the host computer or another USB hub. Configured directly by the operating system, this USB Pocket Hub operates seamlessly with Microsoft’s OpenHCI, Intel’s Universal HCI, and USB 2.0’s latest specification, EHCI. The USB Pocket Hub supports computers using Microsoft Windows or Mac OSX operating systems.
Easy To Use
Connect this tiny device to an available USB port on your notebook computer and your installation is complete. It’s that simple. There are no power switches or buttons to press. The DUB-1040 4 Port USB 2.0 Pocket Hub will always be ready to go. Designed especially for PCand Mac notebook users, this device provides a simple, cost-effective USB connectivity solution for your USB peripherals.
Slim-Sized, Lightweight, Take it with you anywhere
Through a built-in USB cable, which can be neatly placed inside a built-in compartment, the DUB-1040 4 Port USB 2.0 Pocket Hub conveniently connects to your notebook PC. Designed to fit into any notebook bag, the compact size of the device will allow you to conveniently carry it with you wherever you go. Experience the ultimate in portability and expandability with the D-Link DUB-1040 4 Port USB 2.0 Pocket Hub.
Ultimate Performance
The DUB-1040 offers the enhanced performance of USB 2.0 with transfer speeds of up to 480Mbps, while remaining backward compatible with USB 1.1 devices *.
* Maximum transfer rate based on USB 2.0 specifications. Actual data throughput will vary.
** Using a USB 1.1 port will affect device performance.
Ürünler | Destek  | Haberler  | Hakkında |
