Hızlı Arama
Ürün Özellikleri:
2-Port USB 3.0 Adapter for PCI Express
Genel Özellikler:
Fiziksel Özellikler
The interface with the user:
  • 1 PCI Express slot
  • 2 USB input ports, Type A (mother)
Standards:
  • USB 3.0
  • USB 2.0
  • USB 1.1 1
  • USB 1.0
  • OHCI (Open Host Controller Interface)
  • EHCI (Enhanced Host Controller Interface)
  • PCI Express 2.0
Data transfer speed:
  • Super Speed: 4.8 Gbps 2
  • High Speed ​​480 Mbps
  • Full Speed: 12 Mbps
  • Low Speed: 1.5 Mbps
Device connection:
  • Up to 127 devices connected over a consistent
System Requirements:
  • Windows 7/Vista/XP SP3 or later
  • Available PCI Express slot
Physical parameters
Power consumption:
  • Up to 900 mA port
Dimensions:
  • 75.8 x 61.5 x 2.0 mm
Size:
  • 43 g
Working temperature:
  • 0 º to 40 º C
Storage temperature:
  • -20 º to 60 º C
Working humidity:
  • From 0% to 80%, non condensation
Certifications:
  • USB-IFWHQL
  • FCC
  • CE
1 USB 1.1 can affect the device performance.
2 The maximum data transfer rate is defined by the USB 3.0 specification. Actual bandwidth may be different.
All data transfer rates are presented for comparison purposes only. Device specifications for size and appearance are subject to change without notice. Exterior of the device may vary from what is shown.
Ürünler | Destek  | Haberler  | Hakkında |
