DUB-1310EOL EOS
2-Port USB 3.0 Adapter for PCI Express
Nereden Alınır
Tanımlama
Blazing USB 3.0 Speed
Connect your PC to USB 3.0 devices at blazing speeds of up to 5 Gbps - up to 10 times faster than USB 2.0. You can back up your photos, music, and HD movies to an external storage device faster than ever before.
Plug and Play Connectivity
Just insert the card into an available PCI Express x1 slot and run the Setup CD to add 2 USB 3.0 ports to your PC.
Connect all Your Peripherals
Backward compatibility with USB 2.0 and USB 1.1 mean that you can connect any USB device to the DUB-1310. If you need more ports, you can connect additional USB hubs to connect up to 127 devices.
Genel Özellikler
Fiziksel Özellikler
The interface with the user:
  • 1 PCI Express slot
  • 2 USB input ports, Type A (mother)
Standards:
  • USB 3.0
  • USB 2.0
  • USB 1.1 1
  • USB 1.0
  • OHCI (Open Host Controller Interface)
  • EHCI (Enhanced Host Controller Interface)
  • PCI Express 2.0
Data transfer speed:
  • Super Speed: 4.8 Gbps 2
  • High Speed ​​480 Mbps
  • Full Speed: 12 Mbps
  • Low Speed: 1.5 Mbps
Device connection:
  • Up to 127 devices connected over a consistent
System Requirements:
  • Windows 7/Vista/XP SP3 or later
  • Available PCI Express slot
Physical parameters
Power consumption:
  • Up to 900 mA port
Dimensions:
  • 75.8 x 61.5 x 2.0 mm
Size:
  • 43 g
Working temperature:
  • 0 º to 40 º C
Storage temperature:
  • -20 º to 60 º C
Working humidity:
  • From 0% to 80%, non condensation
Certifications:
  • USB-IFWHQL
  • FCC
  • CE
1 USB 1.1 can affect the device performance.
2 The maximum data transfer rate is defined by the USB 3.0 specification. Actual bandwidth may be different.
All data transfer rates are presented for comparison purposes only. Device specifications for size and appearance are subject to change without notice. Exterior of the device may vary from what is shown.
Çözümler
Sipariş Bilgisi
Görseller
DUB-1310
Front view
İndir
Destek Merkezi
