Tanımlama
High-speed USB 3.0 interface with the user
A concentrator is connected to the USB 3.0 devices will have up to 5 Gbps data transfer rate - 10 times greater than with USB 2.0. Now the external devices to copy photos, music and HD movies will take far more quickly than ever before.
Plug and Play connection
Connect the adapter to an available Express Card slot, and then run the installation CD. The computer will be supplemented with two USB 3.0 ports.
The ability to connect to other devices
The DUB-1320 can connect any USB device, because the DUB-1320 is mutually compatible with USB 2.0 and USB 1.1. If necessary, the DUB-1320 can connect additional USB hubs, thus connecting up to 127 devices.
