DUB-1370EOL
7-Port SuperSpeed USB 3.0 Hub
Tanımlama
D-Link’s DUB-1370 7-Port SuperSpeed USB 3.0 Hub provides an easy way to add seven USB 3.0 ports to your notebook or desktop computer. USB 3.0 lets you reach SuperSpeed data transfer rates of 5 Gbps, while also supporting High Speed, Full Speed, and Low Speed transfer rates. The seven USB 3.0 ports are backwards compatible, so all your devices can be plugged in. Compact with a sleek, black design, you can take it with you wherever you go.
Transfer Large Files Faster Than Ever
Use the DUB-1370 to instantaneously share files with colleagues, friends and family. The DUB-1370 can transfer data at 5 Gbps, or ten times faster than USB 2.0. SuperSpeed transfer rates make it faster than ever to transfer music, HD movies, photo albums, and other large files – making waiting for file transfers a thing of the past.
Connect and Charge More Devices
With the DUB-1370, you can conveniently add more USB 3.0 ports to any computer. Now you can connect up to 7 more USB peripheral devices, such as smart phones, tablets, external hard drives, flash drives, and printers – to your notebook or desktop computer. Use the 7-Port SuperSpeed USB 3.0 Hub as a charging station that can charge as many as seven iPads at once, or save time by simultaneously transferring data from one or more flash drives at lightning speeds.*
Compatible with All Your Devices
The DUB-1370 is backwards compatible with your USB 2.0 devices. Featuring seven ports; SuperSpeed, High Speed, Full Speed and Low Speed transfers are supported, ensuring your older devices are still relevant. The DUB-1370 supports previous USB standard devices, while providing USB 3.0 high speed transfers to your newer devices, making the DUB-1370 the ideal portable USB Hub for home and office use.
Super Simple and Convenient
Simply plug in the DUB-1370 to any Mac or PC. It’s that easy - no drivers or software installation required. Now you can connect up to seven additional USB devices to your laptop, notebook, or desktop computer.
Take it with You Anywhere
The DUB-1370 is designed to fit into any notebook bag, making its compact size convenient for taking anyway. Experience the freedom and convenience of portability and expandability with the DUB-1370 7-Port SuperSpeed USB 3.0 Hub.
*Connecting devices beyond 3.8 A total will reduce the power provided to each port, so devices may charge at a slower rate.
Genel Özellikler
Standards
• USB specification version 3.0 (data rates of up to 5 Gbps)
• OHCI
• EHCI
• USB 1.1
• USB 2.0
• USB 3.0
Interfaces
• Seven downstream USB Type A (female) ports
• One upstream USB Type Micro-B (female) port
Connectivity Rules
• Up to 127 devices
• Up to five cascaded hubs
• Maximum cable length between each hub: 3 m
System Requirements
• Windows 10 / 8 / 7 / Vista / XP
• Mac OS
• Linux
Dimensions
• 108.3 x 51.9 x 17.0 mm
Power
• External power adapter 5 V / 4 A
• Supplied: Maximum 2.4 A per port, up to 3.8 A total* (with external AC adapter)
Temperature
• Operating: 0 to 40 °C
• Storage: -20 to 60 °C
Operating Humidity
• 0% to 80% non-condensing
Certifications
• FCC
• CE
• C-Tick
• RoHS
Çözümler
Sipariş Bilgisi
