Hızlı Arama
Ürün Özellikleri:
4-Port USB 2.0 Hub
Genel Özellikler:
Standards
• USB specification version 2.0 (data rates of up to 480 Mbps)
• USB specification version 1.1 (data rates of up to 12 Mbps)
• OHCI
• UHIC
• EHCI
Interfaces
• Four USB Type A (female) downstream ports, white
• Upstream USB Type B (female) port
Connectivity Rules
• Up to 127 devices
• Up to five cascaded hubs
Minimum System Requirements
• Windows 10/8/7/Vista/XP
• Mac OS X 10.3 or above
• Linux
Power LED
• Bus-powered (Blue):
  - Standard Charge Mode
• Self-powered (Green):
  - Fast Charge Mode
Supplied Charging Current*
• Standard Mode:
  - 500 mA total for all USB ports
• Fast Charge Mode*:
  - Max. 1.5 A each for Battery Charging 1.2 compliant devices
  - Max. 2.4 A each for iPad / iPhone
Physical Parameters
Power Input
• 5 V / 2.5 A DC
Temperature
• Operating: 0° to 40°C
• Storage: -40° to 60°C
Humidity
• Operating: 10% to 90%
• Storage: 5% to 95%
Dimensions
• 64 mm x 64 mm x 14 mm
Certifications
• FCC
• CE
• C-Tick
• IC
• RoHS
* The total combined power draw must be under 2.4 A or 12 W.
** D-Link provides a Windows utility for simultaneously syncing and charging iPads with 30-pin connectors.
Fiziksel Özellikler
Ürünler | Destek  | Haberler  | Hakkında |
