Hızlı Arama
Ürün Özellikleri:
7-Port USB 2.0 Hub
Genel Özellikler:
  C1   D1
Standards
• USB specification version 2.0 (data rates of up to 480 Mbps)
• USB specification version 1.1 (data rates of up to 12 Mbps)
• OHCI
• UHIC
• EHCI
Interfaces
• Five USB Type A (female) downstream ports, white
• Two USB Type A (female) downstream Fast Charge ports*, black
• Upstream USB Type B port
• Seven USB Type A (female) downstream Fast Charge ports*, white
• Upstream USB Type B (female) port
Connectivity Rules
• Up to 127 devices
• Up to five cascaded hubs
Minimum System Requirements
• Windows 10 / 8 / 7 / Vista / XP
• Mac OS X 10.3 or above
• Linux
Diagnostic LEDs
• Standard Mode (blue)
• Fast Charge Mode (green)
Supplied Charging Current** • Standard Mode:
 - 500 mA total for all seven front ports
• Fast Charge Mode*:
- 500 mA each for white ports
- 1.2 A each for Fast Charge ports
• Standard Mode:
- Max. 1.5 A each for Battery Charging 1.2 compliant devices
- Max. 2.4 A each for iPad / iPhone
Power Input • 5 V / 3 A DC
Temperature • Operating: 0° to 40°C
• Storage: -20° to 70°C
• Storage: -20° to 60°C
Humidity
• Storage: 5% to 95% non-condensing
Dimensions (L x W x H)
• 100 x 57 x 23 mm (3.94 x 2.2 x 0.9 inches) • 99 x 57 x 25 mm (3.94 x 2.2 x 0.9 inches)
Weight • 85 g (0.19 lbs)
Certifications
• FCC
• CE
• C-Tick
• VCCI
• IC
• RoHS
• FCC
• CE
• C-Tick
• IC
 • RoHS
*Fast Charge Mode available when connected to a Windows PC with utility installed, or when not connected to a PC.
**It is recommended that the total combined power draw not exceed 2.4 A or 12 W.
Fiziksel Özellikler
Ürünler | Destek  | Haberler  | Hakkında |
