Hızlı Arama
Ürün Özellikleri:
PowerLine Switch with 4-port Ethernet 10/100Base-TX, up to 200 Mbit / s
Genel Özellikler:
Fiziksel Özellikler
Minimum system recommendations
• Operating system Windows ®, Macintosh, or Linux
• Ethernet-Adapter
Ports
4-port Ethernet 10/100 Mbit / s (RJ-45)
Data rate
HomePlug AV: up to 200 Mbit / s 1
Indicators
• Power
• Ethernet
• PowerLine
Interfaces
Button for easy connection to the network
Fiziksel Özellikler
Power Input
From 100 to 240 VAC, 50/60 Hz
Power consumption
Maximum: 3 W
Measurements
137 x 110 x 32 mm
Weight
200 grams
Operating temperature
0 to 40 C
Storage temperature
-10 To 70 C
Operating Humidity
From 10 to 90%
Humidity
5 to 95%
Certifications
• FCC
• UL
• CE
1 Maximum throughput based on theoretical transmission PHY rate of the data. Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, and network overhead, lower actual throughput. Interference from devices that produce electrical noise, such as vacuum cleaners and hair dryers can reduce the performance of the product. This product may cause interference and prevent the operation of such devices as lighting with dimmer switch or a touch-button on / off switch, short wave radio communication devices or other devices PowerLine, do not meet the standard HomePlug AV.
Ürünler | Destek  | Haberler  | Hakkında |
