Hızlı Arama
Ürün Özellikleri:
Wireless 802.11n Gigabit Router PowerLine, up to 500 Mbit / s
Genel Özellikler:
Fiziksel Özellikler
Minimum System Requirements
• Windows ®, Macintosh, or an operating system based on Linux
• CD-ROM drive
• Ethernet Adapter
• Internet Explorer 6 or higher, Firefox 3.0 or higher, Safari 3.0 or higher, Google Chrome 2.0 or higher
Device control
• Custom Web-based interface
• SharePort ™ Plus
• UPnP ™ AV Media Server
• Web-access to files
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.3u
• IEEE 1901
• HomePlug AV
Advanced Firewall Features
• VPN Pass-Through/Multi-sessions
• PPTP/L2TP/IPSec
Device Interfaces
• 4-port LAN Gigabit 10/100/1000Base-T (RJ-45)
• 1 port WAN Gigabit 10/100/1000Base-T (RJ-45)
• 1 USB 2.0 port
Frequency range wireless network
From 2.4 GHz to 2.4835 GHz
Data rate
• PowerLine: 500 Mbit / s 1
• 802.11n: up to 300 Mbit / s 2
Antennas
Two internal antenna gain of 2 dBi
Safety
• 64/128-bit WEP
• WPA and WPA2 (Wi-Fi Protected Setup)
Support for SharePort ™
• Ability to connect to USB-port external hard drive or multifunction device
• The ability to share hard drives, print and scan functions
Status indicators
• Power
• Internet
• PowerLine
Fiziksel Özellikler
Nutrition
From 100 to 240
Power consumption
Max. 12 W
Operating temperature
From 0 to 40 C
Storage temperature
-20 To 65 C
Operating Humidity
From 10% to 90%
Humidity
From 5% to 95%
Certifications
• FCC
• UL
• CE
• Wi-Fi
• IPv6
1 Maximum throughput based on theoretical transmission PHY rate of the data. Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, and network overhead, lower actual throughput. Interference from devices that produce electrical noise, such as vacuum cleaners and hair dryers can reduce the performance of the device. This device may interfere with and impede the work of devices such as lighting system with dimmer switch or touch key on / off, short-wave radio devices or other devices PowerLine, not compliant HomePlug AV.
2 Maximum wireless signal rate derived from standard specifications IEEE 802.11n. The data rate may differ significantly from the speed of wireless connections. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual throughput. On the range of a wireless network can be affected by environmental factors.
Ürünler | Destek  | Haberler  | Hakkında |
