DHP-306AV/D1EOL EOS
PowerLine AV Network Adapter
Tanımlama
Data transmission on the mains
Network Adapter D-Link DHP-306AV PowerLine AV HomePlug AV compliant and uses the existing domestic electrical installation for a network or extend your existing network. 1 This adapter is connected to a power outlet, allows access to digital media devices, game consoles, print servers, computers and network storage devices throughout your home.
The ideal solution for applications that require high bandwidth
Network Adapter DHP-306AV provides data transfer rates of up to 200 Mbit / s 2 , which makes the device an ideal solution for applications that require high bandwidth, providing streaming HD video, the work of VoIP-telephony and online gaming without delay. DHP-306AV provides wide bandwidth, allowing users of technology "digital home" use existing electrical wiring to transmit high-quality streaming media.
Easy installation and safety
DHP-306AV plugs directly into a power outlet and does not require additional cables. Expand your home network by connecting multiple devices from the most distant points of the house, or create additional connection by connecting a switch or wireless access point to the adapter. For ease of installation encryption key can be quickly configured at the touch of a button. The adapter supports 128-bit AES data encryption to protect the network from unauthorized connection to the line. With simple installation Plug-and-Play, DHP-306AV adapter is the perfect solution to create a home network.
The power save function
DHP-306AV supports power saving mode to comply with European Directive on the use of energy-using products (EuP). If within a period of time not being transmitted or received, the adapter automatically switches to standby mode, reducing power consumption by more than 70%, and providing automatic energy savings without sacrificing performance.
