DHP-W310AV
802.11n wireless mini-repeater Powerline AV +
Nereden Alınır
Tanımlama
802.11n wireless mini-repeater Powerline AV + DHP-W310AV allows you to expand your existing home network and provides high speed and reliability of the network throughout the house. DHP-W310AV equipped with both wireless and Poweline 1interface that corresponds to the HomePlug AV standard and uses the existing home electrical network to expand the existing network. Wireless connectivity allows increasing the space of the house in which it is possible to use wireless devices.
Working in a hybrid network
DHP-W310AV supports a hybrid network that combines Powerline technology with wireless connectivity, providing a reliable Internet connection throughout the house. DHP-W310AV supports three key functions when used with other hybrid routers D-Link: link aggregation to combine the bandwidth Powerline and wireless networks to provide higher data rate, load balancing to prevent the formation of "bottlenecks", automatically switching to automatic transmitting the data stream to another interface, if a compound at a single interface serious problems arise.
Increased productivity
DHP-W310AV capable of operating at speeds up to 300 Mbit / s on the wireless network at speeds of over 200 Mbit / s network Powerline, allowing you to watch streaming video, download large files, and providing high-speed Internet connection. DHP-W310AV supports the draft IEEE 1905.1 standard to simplify the configuration of hybrid network and its management. Also, the device supports Wi-Fi Multimedia (WMM) Quality of Service to ensure a higher rate of transmission of multimedia data by assigning it a higher priority compared to other types of data.
Secure connections and ease of use
DHP-W310AV supports WPA/WPA2 and WEP encryption to protect your wireless network. This device is equipped with a button Common Connect (standard connection) for easy setup wireless connection via WPS or create a secure connection Powerline. It also supports Wi-Fi Protected Setup (WPS) with PIN-code.
Genel Özellikler
Fiziksel Özellikler
Device Interfaces
• LAN port 10/100 Fast Ethernet with automatic polarity MDI / MDIX
• 802.11n WLAN
• Button Common Connect (standard connection)
• The power switch
• The Reset button
Wireless network
• 802.11n/g/b
• Speed ​​up to 300 Mbit / s 2 (802.11n)
• WPA/WPA2 (Wi-Fi Protected Access)
• 64/128-bit WEP data encryption
Powerline
• HomePlug AV
• IEEE 1901
• The data transmission at speeds of over 200 Mbit / s 3
• Draft IEEE 1905.1
Advanced Features
• Work in a hybrid network
• Support for IPv6
• The power save function
• Wi-Fi WMM Quality of Service
• Technology Multicast over Unicast
• Powerline QoS
Fiziksel Özellikler
Measurements
90 x 65 x 50 mm
Power Input
100-240 VAC, 50/60 Hz
Power consumption
6 W
Temperature
Working from 0 to 40 C
Humidity
Operating: 10% to 90% (non-condensing)
Certifications
• CE LVD
• FCC
• UL
• RoHS
• Homeplug AV
• IPv6
1 power outlets and wiring to be part of the same electrical system. Some conditions, such as laying electrical wiring, can affect the performance of the product. To add new devices to the network requires additional adapters D-Link Powerline AV. To create a network requires at least two adapters D-Link Powerline AV. Connecting this product to a power strip with a surge protector may adversely affect the performance of the product. For best results, plug the adapter directly into a wall outlet.
2 Maximum wireless signal rate derived from IEEE 802.11 standard specifications when used with related Wireless N150 devices.Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual throughput. Wireless signal range can be affected by environmental factors. Wireless network range and data rate are relative indicators of D-Link, based on the technical characteristics of these parameters for the product D-Link-enabled wireless standard 802.11g.
3 Maximum throughput based on theoretical transmission PHY rate of the data. Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, and network overhead, lower actual throughput. Interference from devices that produce electrical noise, such as vacuum cleaners and hair dryers can reduce the performance of the product. This product may cause interference and prevent the operation of devices such as lighting with dimmer switch or a touch-button on / off switch, short wave radio communication devices or other devices Powerline, do not meet the standard HomePlug AV.
Çözümler
Sipariş Bilgisi
Görseller
DHP-W310AV/C
Front view
View from the right
Left side view
Back view
DHP-W310AV
Front view
Front view
İndir
Destek Merkezi
