DHP-P308AV/B1
Mini Powerline AV 500 Adapter with built-in electrical socket (passthrough)
Nereden Alınır
Tanımlama
Powerline AV 500 Adapter DHP-P308AV with integrated electrical socket «passthrough» corresponds to the HomePlug AV standard and uses the standard electrical wiring to create a new or expand an existing home network 1 . This adapter is connected to an electrical outlet that allows you to access digital media devices, game consoles, print servers, computers and network storage devices anywhere in your home.
The ideal solution for applications that require high bandwidth
500 Powerline AV technology provides high data rate compared to conventional devices Powerline AV. Thanks to this device is the ideal solution for applications that require high bandwidth, which provide streaming HD-video, work VoIP-telephony and online gaming without delay. The device provides wide bandwidth, providing users with selecting a digital home technologies, the ability to use existing electrical wires to transmit high-quality streaming media.
Easy installation and integration into network
DHP-P308AV plugs directly into an electrical outlet without requiring additional cables. Expand your home network by connecting multiple devices from the most distant points of the house, or create additional connection by connecting a switch or wireless access point to the adapter. For ease of installation, you can configure the encryption key at the touch of a button. The adapter supports 128-bit AES encryption to protect your network from unauthorized connection to the line. With simple installation Plug-and-Play, DHP-P308AV adapter is the perfect solution to create a home network.
In addition, the adapter is equipped with a built-in socket «passthrough», through which a main outlet can be connected to other electrical devices. This adapter filters electrical noise from the connected device, which may affect Powerline-compound.
The power save function
DHP-P308AV supports power saving mode in accordance with the European Directive on the use of energy-using products (EuP). If within a period of time not being transmitted or received, the adapter automatically switches to standby mode, reducing power consumption by more than 70%, and providing automatic power savings without sacrificing performance.
QoS
The adapter supports the mechanism of QoS (Quality of Service), used to prioritize traffic is transmitted. QoS mechanism enables fast transfer of IPTV, HD-video and online games without delay by assigning a higher priority multimedia traffic in comparison with the other data packets.
1 electric plug and wiring must be part of the same electrical system. Some conditions, such as laying electrical wiring, can affect the performance of the product. To add new devices to the network requires additional adapters D-Link Powerline AV. To create a network requires at least two adapters D-Link Powerline AV. Connecting this product to a power strip with a surge protector may adversely affect the performance of the product. For best results, plug the adapter directly into a wall outlet.
Genel Özellikler
Fiziksel Özellikler
Interfaces
• Powerline: power connector (depending on country)
• Passthrough: power connector (depending on country)
• Ethernet: Fast Ethernet port with RJ-45
Standards
• IEEE 802.3
• IEEE 802.3u
• HomePlug AV
• IEEE 1901
Safety
128-bit AES data encryption
Indicators
• Power
• Ethernet
• Powerline
The modulation scheme Powerline
Symbol OFDM modulation
Bandwidth Powerline
From 2 MHz to 30 MHz
Data rate
• Powerline: 200 Mbit / s (physical rate) 2
• Ethernet: 10/100 Mbit / s (Auto-Negotiation)
Fiziksel Özellikler
Measurements
91,5 x 62 x 35,5 mm
Saving energy
Support power saving mode
Temperature
Working from 0 to 40 C
Humidity
Operating: 10% to 90% (non-condensing)
Certifications
• CE LVD
• FCC
• UL
• CE EMC Class B
• RoHS
• ErP
Electrical outlet (depending on country)
• Electrical outlet type EU: 250 V / 16 A max
• Electrical outlet type UK: 250 V / 13 A max.
• Electrical outlet type FR: 250 V / 16 A max
• Electrical outlet type US: 125 V / 12 A max
• The electrical socket type AU: 250 V / 10 A max
Power Input
100-240 VAC
2 Products Powerline AV + are equipped with more powerful CPU than providing data transfer rate 200 Mbit / s products Powerline AV, to increase performance. Maximum throughput based on theoretical transmission PHY rate of the data. Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, and network overhead, lower actual throughput. Interference from devices that produce electrical noise, such as vacuum cleaners and hair dryers can reduce the performance of the product. This product may cause interference and prevent the operation of devices such as lighting with dimmer switch or a touch-button on / off switch, short wave radio communication devices or other devices Powerline, do not meet the standard HomePlug AV.
Çözümler
Sipariş Bilgisi
Görseller
DHP-P308AV/B1
Front view
Back view
Back view
View from the right
İndir
Destek Merkezi
