DAP-1522EOL EOS
Xtreme N Duo Wireless Bridge/Access Point
Tanımlama
CONSERVE ENERGY WITH GREEN ETHERNET TECHNOLOGY
DAP-1522 showcases D-Link's Green Ethernet technology, which assists in conserving energy based on the  deployment of your device. Green Ethernet technology saves power by deciphering cable length to adjust its  power consumption so that energy is effciently used. Unused ports automatically enter power-saving mode to keep energy use to a minimum without sacrifcing performance.
HIGH-DEFINITION PERFORMANCE
The DAP-1522 allows you to easily upgrade any router to support streaming of High-Defnition (HD) multimedia content over a wireless connection. Connect up to four Ethernet-enabled devices of your entertainment center to  the DAP-1522, such as game consoles, Digital Video Recorders (DVR), and Digital Media Adapters (DMA) simultaneously. You can also upgrade your network to support dual-band wireless streaming by connecting a DAP-1522 to your router.
DUO TECHNOLOGY
Xtreme N Duo is the latest addition to the award-winning Xtreme N product family. The Duo technology in the  DAP-1522 supports selectable dual band N (2.4GHz or 5GHz) wireless signals. This allows you to check e-mail and browse the internet using existing 802.11g and popular draft 802.11n products or stream high-defnition movies and other media on the 5GHz band. The 5GHz band helps avoid interference by providing a clearer  wireless band for HD signals.
QoS AND TRAFFIC MANAGER TO PRIORITIZED TRAFFIC
The Quality of Service (QoS) feature allows users to regulate the fow of data through the DAP-1522 by assigning levels of priority to each packet. This feature comes with the option to set bandwidth use based on LAN port or on protocol. Traffc Manager provides assigns the transmission of the device's entire bandwidth as well as rules for data transmission. Option to deny unlisted clients prevents unknown user from stealing  bandwidth and transfer rates high.
Genel Özellikler
STANDARDS
+  IEEE 802.11a 2
  + IEEE 802.11b
+  IEEE 802.11g  + IEEE 802.11n draft
+  IEEE 802.3
DEVICE INTERFACE
+  Factory Reset Button
+  4 Giga LAN Ports
+  Internal Antenna
+  1 Push-Button for Wi-Fi Protected Setup™
+    1 3-way switch for: AP, Bridge and Auto mode
OPERATING FREQUENCY
+  2.4 to 2.4835GHz
+  5.15 to 5.35GHz
+  5.47 to 5.85GHz
OPERATING CHANNELS
+  11b/g
  11 channels for USA
  13 channels for EU
+  11a
  24 non-overlapping channels for USA
  19 non-overlapping channels for EU
RADIO AND MODULATION SCHEMES
+ DBPSK  + QPSK
+ 16QAM  + 64QAM with OFDM
+ DQPSK  + DBPSK
+ DSSS  + CCK
OPERATION MODES
+ AP  + Auto
+ Bridge
ANTENNA TYPE
+  Internal PIFA *2
MAXIMUM TRANSMIT OUTPUT POWER
+  For 802.11a: 17dBm (typical)
+  For 802.11b: 20dBm (typical)
+  For 802.11g: 19dBm (typical)
+  For 802.11n: 17dBm (typical)
RECEIVE SENSITIVITY
+  For 802.11a, at 10% PER:
  6Mbps: -88dBm,  9Mbps: -87dBm
  12Mbps: -86dBm,  18Mbps: -84dBm
  24Mbps: -82dBm,  36Mbps: -78dBm
  48Mbps: -72dBm,  54Mbps: -71dBm
+  For 802.11b, at 8% PER:
  1Mbps: -90dBm  2Mbps: -90dBm
  5.5Mbps: -88dBm  11Mbps: -85dBm
+  For 802.11g, at 10% PER:
  6Mbps: -90dBm  9Mbps: -88dBm
  12Mbps: -85dBm  18Mbps: -83dBm
  24Mbps: -80dBm  36Mbps: -78dBm
  48Mbps: -74dBm  54Mbps: -73dBm
+    For 802.11n(5G Band), at 10% PER:
  HT20
  87dBm at MCS0  85dBm at MCS1
  82dBm at MCS2  78dBm at MCS3
  76dBm at MCS4  72dBm at MCS5
  70dBm at MCS6  69dBm at MCS7
  HT40
  84dBm at MCS0  81dBm at MCS1
  79dBm at MCS2  75dBm at MCS3
  73dBm at MCS4  68dBm at MCS5
  66dBm at MCS6  65dBm at MCS7
+  For 802.11n(2.4G Band), at 10% PER:
  HT20
  HT40
SECURITY
+  64/128-bit WEP
+  WPA™- PSK, WPA2 ™ PSK (Wi-Fi Protected Access)
+ WPS (WiFi Protected Setup)
DEVICE MANAGEMENT
+  Internet Explorer
® v6 or later
+ Mozilla
® Firefox
® v1.5 or later
+ Other Java-enabled Browsers
LEDS
+ Power
+ Status- LED: AP
+ Status- LED: Bridge
+  LAN
CERTIFICATIONS
+  FCC  + IC
+ CE  + C-Tick
+ CSA  + WMM PS
+ Wi-Fi 11n draft 2.0
+ Wi-Fi Protected Setup
STORAGE HUMIDITY
5% to 95% non-condensing
DIAGNOSTIC LED
+ Power  + Bridge
+ AP  + LAN
OPERATING TEMPERATURE
0˚ to 40˚ C
STORAGE TEMPERATURE
-20˚ to 65˚ C
OPERATING HUMIDITY
10% to 90% non-condensing
1 Maximum wireless signal rate derived from IEEE Standard 802.11a, 802.11g, and draft 802.11n specifcations. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffc, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
2 Computer must adhere to Microsoft’s recommended System Requirements.
3 Latest software and documentation are available at http://support.dlink.com.tw.
This product is based on IEEE draft 802.11n specifcations and is not guaranteed to be forward compatible with future versions of IEEE 802.11n specifcations. Compatibility with draft 802.11n devices from other manufacturers is not guaranteed. All references to speed and range are for comparison purposes only. Product specifcations, size, and shape are subject to change without notice, and actual product appearance may differ from that depicted herein.
©2008 D-Link Corporation. All  rights  reserved. D-Link,  the D-Link  logo, Xtreme N,  the Xtreme N  logo, Duo, Xtreme N Duo, MediaBand, and Wireless Bridge are trademarks or registered trademarks of D-Link Corporation or its subsidiaries in the United States and/or other countries. Windows Vista is either a registered trademark or trademark of Microsoft Corporation in the United States and/or other countries. Windows is a registered trademark of Microsoft Corporation in the United States and other countries. Other trademarks or registered trademarks are the property of their respective owners
Çözümler
Sipariş Bilgisi
DAP-1522   802.11n DualBand High-Speed Bridge/AP
Görseller
DAP-1522
Back view
Front view
İndir
Destek Merkezi
