DWL-1800REOL EOS
Tanımlama
Point-to-Multipoint Architecture
The DWL-1800 Wireless Outdoor Bridge series consists of a Base Station
Bridge DWL-1800B that is used to connect a single remote site or
multiple remote sites to a central server or Internet connection. In a
multipoint configuration, it is the central unit; in point-to-point
configurations, it must be installed at one end of the link. The Remote
Station Bridge is a DWL-1800R. Up to 128 Remote Station Bridges can be
simultaneously connected to a single Base Station Bridge, forming a
single wireless LAN.*
Weather-proof Design
Each Base Station Bridge DWL-1800B and Remote Station Bridge DWL-1800R
consists of an Indoor and an Outdoor unit. The Indoor unit supplies
power, interfaces to the LAN
inside the building through an Ethernet port, provides data
connectivity to the outdoor unit. The Outdoor unit (normally installed
on rooftop) is connected the Indoor unit through a sealed, water-proof
interface cable, which can run up to 90 meters long. The Outdoor unit
also has a front-end radio with integrated 16 dBi flat panel antenna
capable to transmitting data up to 25 km in FCC and 10km in ETSI. This
antenna is mounted on the front cover of the Outdoor unit, which also
functions as a protective sun cover.
Indoor/Outdoor Architecture
The Outdoor unit and its baseband (Ethernet) interface cable to the
Indoor unit are completely sealed for water-proof, and can withstand
extreme temperatures and harsh summer/winter weather. Power Over
Ethernet is built in, allowing power to be supplied to the Outdoor unit
via the interface cable. The Outdoor unit thus can be placed on a
rooftop or other where no power outlets are available.
Easy Installation
Extensive LED diagnostics are provided, including 10-LED RSSI bar
display for easy antenna alignment. Easy maintenance allows multiple
units to be configured and remotely upgraded. A user friendly
configuration and management utility is provided.
