DWA-125EOL EOS
Wireless 150 USB Adapter
Tanımlama
HIGH-SPEED WIRELESS NETWORKING
Connect to a high-speed wireless network with the D-Link Wireless 150 USB Adapter and enjoy surfng the web, checking e-mail, and chatting with family and friends online. The DWA-125 uses Wireless 150 technology, which offers increased speed and range over the 802.11g/b standard1 giving you a faster, more reliable wireless connection.
CONNECT SECURELY TO YOUR WIRELESS NETWORK
To protect your data and privacy, the Wireless 150 USB Adapter supports WEP, WPA, and WPA2 encryption for connecting to a secure wireless network, keeping your network traffc secure.
COMPATIBILITY ASSURANCE
The Wireless 150 USB Adapter provides a high-speed connection to other Wireless 150 or 802.11n devices and is backward compatible with 802.11g/b, ensuring compatibility with a wide range of wireless routers and networks.
EASY TO INSTALL & CONNECT
D-Link’s Quick Setup Wizard provides easy setup of your USB adapter so you can get connected quickly. Wi-Fi Protected Setup (WPS) sets up a secure wireless connection, so all you have to do is push a button to automatically create a secure wireless connection to your network, doing away with the need for confguring complicated settings.
Genel Özellikler
SYSTEM REQUIREMENTS
Computer with:
- Windows 2000 (SP4), XP (SP2), or Vista (32 or 64-bit) or higher
- CD-ROM drive
- 20MB hard disk space
- Available USB port
STANDARDS
- IEEE 802.11g
- IEEE 802.11b
- USB 2.0
FREQUENCY RANGE
2.4GHz to 2.4835GHz
ANTENNA
Integrated Antenna
SECURITY
- 64/128-bit WEP data encryption
- Wi-Fi Protected Access (WPA/WPA2-PSK, WPA/WPA2-EAP)
- 802.1x
Çözümler
Sipariş Bilgisi
DWA-125  Wireless 150 USB Adapter
Görseller
DWA-125/B1
Front view
İndir
Destek Merkezi
