DAP-1360EOL EOS
DAP-1360 Wireless N Range Extender
Nereden Alınır
Tanımlama
The Wireless N Range Extender (DAP-1360) is designed for users looking to create a new wireless network or extend coverage of an existing wireless network.
MULTIFUNCTIONAL RANGE EXTENDER
The D-Link® Wireless N Range Extender (DAP-1360) is designed for users looking to create a new wireless network or easily extend coverage of an existing wireless network. The DAP-1360 also provides an excellent solution for upgrading your wireless network to Wireless N technology, which significantly outperforms previous-generation Wireless G. Flexible and multifunctional, the DAP-1360 includes a variety of features allowing it to serve as an access point, bridge with access point, repeater, or wireless client and is ideal for use in an existing home or small office wireless network.
CREATE A WIRELESS NETWORK
Simply create a new Wireless N network by connecting the DAP-1360 to your router or easily extend your wireless coverage by using the DAP-1360's repeater mode feature. Use your new wireless network to share a high-speed Internet connection, stream high-definition (HD) video, play multiplayer games, or make phone calls (VoIP). The DAP-1360 is also backward compatible to work with your existing Wireless G devices.
ADVANCED NETWORK SECURITY
The DAP-1360 supports the latest wireless security features to help prevent unauthorized access, be it from over a wireless network or the Internet. Support for WPA™ and WPA2™ ensure that you will be able to use the best possible encryption regardless of your client devices.
Delivering superior wireless performance, clarity, and coverage, the Wireless N Range Extender (DAP-1360) is an ideal solution for creating or extending a home or office wireless network.
WHAT THIS PRODUCT DOES
Use the Wireless N Range Extender (DAP-1360) to create a new wireless network or simply extend your existing wireless network coverage to reach greater distances throughout a home or office.
WHY WIRELESS N IS BETTER
This Wireless N Range Extender uses Wireless N technology with multiple intelligent antennas to maximize the speed and range of your wireless signal to significantly outperform previous-generation Wireless G devices*. The antennas make use of your home’s environment by bouncing multiple wireless signals off walls and ceilings to work around obstructions and help eliminate dead spots.
WIRELESS N RANGE EXTENDER BENEFITS
  • ETHERNET TO WIRELESS: Add wireless connectivity to an Ethernet-enabled device
  • ACCESS POINT: Create a new wireless network in a different part of your home
  • WIRELESS REPEATER: Extend your existing wireless network coverage to reach greater distances across your home or office
  • CONNECT TWO NETWORKS TOGETHER: Wirelessly bridge two or more networks together
* Maximum wireless signal rate derived from IEEE Standard 802.11 specifications. Actual data throughput will vary. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range. Wireless range and speed rates are D-Link RELATIVE performance measurements based on the wireless range and speed rates of a standard Wireless G product from D-Link. Maximum throughput based on D-Link Wireless N devices
Genel Özellikler
Specifications
Standards
IEEE 802.11n
IEEE 802.11g
IEEE 802.3u
Interface Type
1 10/100 LAN Port
Antenna Type
2 External Detachable Antennas
Security
Wi-Fi Protected Access (WPA™, WPA2™)
Wi-Fi Protected Setup™ (WPS)
WPS Push Button
Device Management
Internet Explorer® v7 or Later; Mozilla® Firefox® v3.0 or Later; or other Java-enabled Browsers
LEDs
Power
Wireless
Internet
LAN
Certifications
FCC Class B
Wi-Fi®
IC
Dimensions
Item (HxWxD): 5.9” x 4.5” x 1.4” (149.9mm x 114.3mm x 35.6mm)
Packaging (HxWxD): 10.9” x 2.7” x 8.3” (276.9mm x 68.6mm x 210.8mm)
Weight
Item: 0.5 lbs (0.23kg)
Packaging: 1.7 lbs (0.77kg)
Warranty
1 Year Limited*
Minimum System Requirements
Computer with:
Windows® 7, Windows Vista®, Windows® XP SP3 **, or Mac OS® X (v10.4)***
Internet Explorer® v7 or Mozilla® Firefox® v3.0
CD-ROM Drive
Network Interface Card
For Internet Access:
Cable or DSL Modem for High-Speed Internet Connection
Wireless Router
Subscription with an Internet Service Provider (ISP)
Recommended System Requirements
For Optimal Wireless Performance, use with one of the following Wireless N routers:
Xtreme N Duo Media Router (DIR-855)
Xtreme N Dual Band Gigabit Router(DIR-825)
Xtreme N Gigabit Router (DIR-655)
Xtreme N Gaming Router (DGL-4500)
Package Contents
2 Detachable Antennas
CAT5 Ethernet Cable
Power Adapter
Quick Install Guide
CD-ROM with:
Installation Wizard
Product Documentation
* 1-Year Limited Warranty available only in the U.S.A and Canada.
** Computer must adhere to Microsoft's recommended System Requirements.
*** The software included with this product is not Mac-compatible.
All references to speed and range are for comparison purposes only. Product specifications, size, and shape are subject to change without notice, and actual product appearance may differ from that depicted herein.
Fiziksel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DAP-1360
Front view
Back view
İndir
Destek Merkezi
